Old 11-17-2017, 11:34 AM   #1
1973 31' Sovereign
Franklin , Indiana
Wanting to move bath to center of 73 sovereign
Need advice on what type of tanks to use. I am moving bath to center of trailer and going to up date waste system. Thinking of going with 1974 type of set up. Any ideas or advice?
Greg Black is offline   Reply With Quote
Old 03-17-2018, 11:40 AM   #2
1964 22' Safari
Dallas , Texas
Did you ever move forward with your mid bath plans? I am thinking about doing the same with my 68 Safari. I have good locations for the grey and black tanks but wondering about how best to locate the clean-out ports ..especially distance of the black tank ( near the axle ) and the distance to the rear of the trailer. If I go to the side near the wheel well it will step down around the frame ( Will that cause clearance issues). Love to hear further comments on the subject.
JDbuilder is offline   Reply With Quote
Old 03-17-2018, 07:56 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello from Colorado jdbuilder: I think most of new Airstream trailers have the bathroom in the center of the trailer. Our 86 Limited does. Rear bedrooms make more sense, but more importantly getting the water weight toward the center of the trailer makes sense. Further, Airstream has been using below the frame rail sewer discharge ports for a long time.
That said, my 75 Overlander is a rear bath model, with the waste water tanks located in the rear, the the discharge port through the frame rail just before the rear bumper. Not the greatest idea Airstream ever had.
I used to own a 66 Trade Wind 24' tandem axle. It is a rear bath. I reconfigured the waste water system to include a nice sized gray water tank and new black water tank. I routed the dump valve manifold below the frame rail. Yep, it took away some ground clearance. I find it effective in scraping dead raccoons of the highway.
I recommend building a street side below the frame rail sewer discharge. Since you plan a center bath, make the drain port close to the rear wheel like our 86 has.
David
Name:	1404 Waste Tanks Installed (Small).JPG
ID:	306555   Click image for larger version
Name:	1708 Sale Hook Ups (Small).JPG
Name:	1408 Ground Clearance 66 (Small).jpg
ID:	306557   Click image for larger version
Name:	1408 Ground Clearance 86 (Small).jpg
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
dbj216 is online now   Reply With Quote
Old 03-21-2018, 07:19 AM   #4
1964 22' Safari
Dallas , Texas
Moving bath to center in 68 Safari
Thanks for your reply. I didn't see your pictures at first and those are most helpful. It does reduce the clearance quite a bit. Has that caused you any problems? I guess running the black waste lines to the rear through the strut openings would be too far unless one has a macerating toilet? My new axle is coming in a few weeks and I need to get on to the plumbing. I appreciate the input in my learning curve. JD
Old 03-21-2018, 06:51 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
The reduction in ground clearance on the Trade Wind did not cause any problems back in Minnesota. I did take a straight edge from the rear tire contact patch to the rear bumper and the "departure angle" cleared my tank pan. A center bath allows even more "departure angle". Here is a photo of the pan around the tanks. It is 4" below the frame rails. My 86 Limited is about the same size.
Some Airstream boondockers take their trailers up old logging roads or mining trails. Very rough roads with big rocks and washouts might damage the tank pan. I don't use my Airstream in this manner.
Here is a thread of a AirForums participant who built a center bath in his 68 Trade Wind. It may offer some ideas for you.
http://www.airforums.com/forums/f125...me-104003.html
Yep, the easiest way to repair a broken bathtub is to start over with all new. I built a new bath in the rear of my Trade Wind. No bathtub repairs required.
David
Name:	1406 Waste Tanks Pan Mounted Front (Mobile).jpg
sovereign
Wanting a 28+ trailer with central bath for full-time family of 4 venymae Airstream Classifieds 0 07-24-2016 10:55 AM
Moving rear bath to center split bath jrossingaul Plumbing - Systems & Fixtures 8 03-08-2013 12:03 AM
Center bath or rear bath Sovereign? desertratt General Repair Forum 9 09-24-2011 09:40 PM
want to trade center bath for rear bath? nomader General Repair Forum 7 02-23-2010 05:40 PM
Move a rear bath to a side bath? rjacques General Repair Forum 11 12-27-2008 10:25 PM
