Old 05-11-2018, 09:01 AM   #1
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Toilet Flange
Doing a flooring replacement in the bath of our 1994 Excella, and would like to rotate the toilet about 25 degrees and install a riser. How is the toilet flange attached to the black tank? Is it screwed in or glued? I have removed all the screws that anchor to the floor, but have not tried to rotate the flange. Thank you for any and all advice. Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 05-11-2018, 10:29 AM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Mine is slip fit into the tank top and clamped at the neck. My toilet is on a wooded pedestal with a removable panel in the front. Access is easy. I had to change my flange after it broke from one to many pull and reseat jobs.
CRH is offline   Reply With Quote
Old 05-11-2018, 08:15 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Tried to pry it around by putting a bar between the bolts, but no luck. I carefully tapped it counter clockwise with a punch and hammer on the side of the flange where the bolts attach. Got lucky and it moved slowly to where I wanted it. Project completed!!!
ACI #7394
1994 Excella 34'
Hensley Hitch
Black Tank-To Flange or not to Flange? Mrwaterway Waste Systems, Tanks & Totes 4 12-02-2009 09:02 AM
Need flange for my toilet-b/w tank 68Glbtrotter Waste Systems, Tanks & Totes 7 01-24-2006 08:07 PM
Toilet Flange won't unscrew!! mello mike Sinks, Showers & Toilets 11 07-11-2005 08:34 PM
HELP - Removing Toilet Flange Joe Z Sinks, Showers & Toilets 4 07-12-2004 10:10 PM
Toilet Flange Sneakinup Sinks, Showers & Toilets 16 06-30-2004 03:16 PM
