Old 03-05-2020, 08:37 AM   #1
Lafayette , Louisiana
Toilet
Got my 2019 fc in dec the toilet doesn’t hold water.
Is there an easy fix or do I have to replace it under warranty?
Whitn37140 is offline   Reply With Quote
Old 03-05-2020, 08:43 AM   #2
2019 27' International
Western , North Carolina
Have you checked to make sure there is grease on the seal at the bottom where the flap opens? They make special stuff or in a pinch you can use dielectric
2019 International Serenity 27 FBQ “Serenity”
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 03-05-2020, 08:54 AM   #3
2018 25' International
Slidell , Louisiana
In addition to the grease, first wipe and clean the underneath surface of the seal.
Unless the seal is visibly damaged warped or pitted, it should seal after cleaning and greasing. If you don't have dielectric grease you can get it at any auto parts store. If you just want to see if this solves the issue, Vaseline will work temporarily, it just doesn't stick around as long.
Brian
BayouBiker is online now   Reply With Quote
Toilet seal for vintage toilet thinktankair Waste Systems, Tanks & Totes 0 06-09-2014 12:37 AM
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 06:12 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Thetford Toilet Repair??? Galaxy Low Profile ViewRVs Sinks, Showers & Toilets 11 05-03-2010 03:27 PM
Raise the toilet FrankR Sinks, Showers & Toilets 0 03-15-2002 09:57 PM
