Old 06-28-2018, 02:40 PM   #1
1981 31' Excella II
Prescott , Arizona
Thetford Waste Valves R&R
Im working on a 1981 Airstream Excella II replacing black and gray water wastes valves, curious if anyone has used the Thetford #08669 3 valve instead of the Thetford #08708 with Thetford Slip in valve flange? In other words would the #08669 spigot side slide into a waste tank 3 1/2 ID and connect with a hose clamp. Im wanting to have the least amount of connections. Thx in advance
Cedarhill is offline   Reply With Quote
Old 06-28-2018, 04:05 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I'm also doing the 'valve thing' on our '03 Classic.
Just called ODM Parts Department today Got all the info I needed. Will be ordering when it's disassembled.
Give them a call...good folks, very helpful. 👍
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Replacing Thetford waste valves A W Warn Waste Systems, Tanks & Totes 38 10-26-2019 11:25 AM
Replaced Thetford Waste Valves on 1995 Excella CRH Waste Systems, Tanks & Totes 4 07-05-2016 01:02 PM
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 06:07 AM
Convert or Replace Thetford Waste Valves Emh142 Waste Systems, Tanks & Totes 2 05-15-2011 07:05 PM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
