Old 03-24-2018, 12:13 PM   #1
1966 20' Globetrotter
Tacoma , Washington
Send a message via Skype™ to AirGT65
Tanks on 20' 1965 Globetrotter twin?
Hi all,
We have returned as Airstream owners after a 25 year absence, and I'm just getting to know our newly pruchased 20' 1965 Globetrotter Twin. My understanding from the previous owners is that it has a combined grey/blackwater tank of approximately 10 gallons and a fresh water tank of around 30 gallons.
Questions: (1) Do those capacities sound about right?, (2) Is there a relatively inexpensive way to increase the grey/black water capacity?, (3) Any advice on installing a tank monitor system, like the SeeLevel? Thanks in advance for any help you can give me.
AirGT65 is offline   Reply With Quote
Old 03-24-2018, 03:29 PM   #2
1972 25' Tradewind
McHenry County , Illinois
Welcome to the Forum.
The tank sizes are about right.
The Airstreams of this Vintage technically only had the black tank. The grey water was intended to be drained into a gopher hole or a portable tank sometimes referred to as a “Blue Boy” due to it's color.
I my '67 GT had a similar set-up as yours. You have the shower. The '67 had a bathtub. It was possible to use the black tank to catch some grey water by opening the dump valve. However this only caught a few extra gallons before backing up into the bathtub. I suspect you will have the same condition.
There are several threads about adding a grey tank to Vintage trailers. Use the Google search function on the toolbar. I don't see a problem adding sensors when the floor is out and the tanks are accessible.
I currently use a 12 Gallon Thetford portable tank with the Tradewind. Look for a cap to fit on the waste collector by the dump valve with a hose fitting. Vintage Trailer Supply has the cap and various tanks to retrofit the older rigs. Most RV dealers will have the portable tanks.
Good luck,
Tom
Tom Nugler is offline   Reply With Quote
Replacing water tanks, holding tanks & battery? Nelsons 1956 - 1959 Flying Cloud 57 10-19-2014 09:21 AM
Holding tanks gage is there a key or plugin to test the levels of the tanks. Buckshot 1997 - 1999 Safari 1 08-18-2014 09:25 PM
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 01:37 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 12:42 PM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 09:34 AM
