Old 01-09-2018, 11:13 PM   #1
1970 25' Caravanner
Incline Village , Nevada
Sources for 4" height holding tanks
Is Vintage Trailer Supply the only place that sells holding tanks that are 4" in height? Looking to add a grey tank to fit snugly between floor and belly pan so max height is 4". Probably have called or visited a dozen or so websites for other companies and am not able to find something in that height. Nothing against ordering from VTS, just wanted to get a comparison elsewhere if available.
Jeremy9107 is offline   Reply With Quote
Old 01-15-2018, 09:48 AM   #2
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
I purchased mine from VTS and they installed my outlets and vents where I needed them and they mounted perfectly over my axles on my 72 31' Sovereign. Could never find any others. Good luck
cole3444 is offline   Reply With Quote
Old 01-15-2018, 09:52 AM   #3
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Some tank manufacturers will make custom tanks, though they are not likely to be cheaper than the VTS ones.
BambiTex is offline   Reply With Quote
Old 01-15-2018, 07:26 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi: Have you checked out Inca Plastics in California? They have been molding holding tanks for 60 years. They have many of the old Airstream molds. I'm pretty sure I saw 4" high tanks in their catalog.
Just download their pdf catalog and start paging through until you find a tank that fits your location dimensions.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Link to our 1976 Renovation Project:
https://www.airforums.com/forums/f221...ct-202081.html
Old 01-15-2018, 11:43 PM   #5
1970 25' Caravanner
Thanks all. David. Looked at the Inca catalogs. They do have some that are close to height restriction I have. Going to call them tomorrow and query further. Trying to maximize width and length of the 4" high tank to squeeze more holding capacity thus wondering if anything available outside of VTS option.
Old 01-16-2018, 06:45 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I dropped two 1975 Inca Plastic tanks out of my Overlander. It was one of those dirty jobs you enjoy doing. I am putting two new bigger Inca Plastic tanks back in with different locations under the trailer. Give them a call with your dimensional requirements and see if they don't have a match. It takes a bit of patience to get ahold of them. Busy I guess. I had better luck with e-mail.
David
Name:	1710 Waste Tank Black Inca PN (Small).JPG
ID:	302564   Click image for larger version
Name:	1710 Waste Tank Black and Grey (Small).JPG
WBCCI #8607
VAC Region 11
Old 01-16-2018, 10:22 PM   #7
1970 25' Caravanner
That smaller tank in your photo looks about right for my purpose. Called Inca several times today. Chose several options on their voice menu. All options led to an unanswered phone and answering machine for Bill. Tried emailing but email came back as undeliverable...
Old 01-17-2018, 06:47 PM   #8
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Yep, that's Inca Plastics. Same thing happened to me. Customer communications could be improved. I have talked to Bill Odell on the phone, sounds like a nice guy. I found Inca Plastics was more responsive to email, like so many folks are.
Try this email address listed below. Tell Bill you are interested in this part number or that part number found in their catalog, and you want a price and delivery for consideration. I bet you will get a reply. In a day or two. I paid about $240 a tank plus shipping.
David
bodell@incaplastics.com
WBCCI #8607
VAC Region 11
Old 01-23-2018, 10:47 AM   #9
1959 24' Tradewind
Twin Falls , Idaho
I bought two of the 4" gray tanks and a fresh water 12x12x50" from VTS. Getting ready to install the gray tanks this week. Ordering was easy and I was able to talk to someone both times I called, just so I could validate what I was thinking about doing. You just decide where you want the spin weld fittings and that's it. Took about two weeks from ordering until I received them.
Regards,
Tony
Trons4u is offline   Reply With Quote
Old 01-23-2018, 11:21 AM   #10
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
David
The tank I ordered from VTS was made by Inca
Old 01-31-2018, 10:35 PM   #11
1970 25' Caravanner
Was able to get email response from Inca and they do carry the 4" height tank that VTS carries. Slightly lower price. Still waiting on follow up email reply, but asked if they allow pick up and if they happen to carry any other 4" max height tanks with wider or longer dimensions? Not sure if they do custom tanks.
Tough place to get through but like the option of a place nearby.
Old 02-01-2018, 07:24 PM   #12
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi: Inca is a rotomolder. Them mold tanks out of polyethylene. The tanks are the shape of the mold. I'll bet they don't make custom tanks, but I don't know for sure.
Some guys buy two tanks and daisy chain them together to get added capacity.
David
WBCCI #8607
VAC Region 11
Old 02-01-2018, 07:49 PM   #13
wahya's Avatar
oz , Tennessee
Vintage base camp in Lexington ky. 179.00 they also have straps for mounting 60.00
wahya is offline   Reply With Quote
Old 02-09-2018, 09:19 PM   #14
1970 25' Caravanner
wahya thanks for that hint. they confirmed they do have the same tank Inca and VTS sell, a bit cheaper too. curious to know if this is something they buy from Inca then resell....they have yet to respond to that. they did confirm that this is the only size they sell and they do not do custom tanks.
search continues for a 4" high tank that is slightly bigger than the stock size of 50"x21". hoping to squeeze out a bigger capacity so 2 of them matches the size of the freshwater tank. as it stands now, the stock freshwater tank is 45 gallons, and these stock gray tanks are 16 gallons each.
Old 02-15-2018, 09:52 AM   #15
1959 24' Tradewind
Twin Falls , Idaho
Here's a picture of my installation just in case you wanted to see how they look
ID:	304304   Click image for larger version
Regards,
Tony
Old 03-07-2018, 04:59 PM   #16
alfred , New York
Trons4U,
what was your grey water tanks supported by? is it necessary to support the entire tank underneath or around the perimeter and across the middle? looks like you put bubblewrap underneath... for insulation or for cushion or both?
thanks!
diane
nevermoor is offline   Reply With Quote
Old 03-07-2018, 05:55 PM   #17
1959 24' Tradewind
Twin Falls , Idaho
It's actually upside down right now. So I have reflectix then subfloor. I used elevator bolts on the straps that you see
Sent from my Nexus 6P using Airstream Forums mobile app
Regards,
Tony
Hitch Height vs. Ball Height adamwright Towing, Tow Vehicles & Hitches 5 02-12-2015 03:24 PM
Replacing water tanks, holding tanks & battery? Nelsons 1956 - 1959 Flying Cloud 57 10-19-2014 08:21 AM
Holding tanks gage is there a key or plugin to test the levels of the tanks. Buckshot 1999 Safari 1 08-18-2014 08:25 PM
The "GEO System" Balck and Grey tank holding tanks adonh Waste Systems, Tanks & Totes 1 05-06-2013 12:05 PM
