Old 05-24-2020, 07:14 AM   #1
1967 28' Ambassador
South Dartmouth , Massachusetts
side vent on gray tank??
Hey all,
Bought someone's project and half the battle is detective work to figure out what the last owner was shooting for.
Do we think this opening on the side of the gray tank was for the 1.5" air vent/exhaust pipe to the outside? Wouldn't that limit the holding capacity?
Thanks all. In the process of figuring out what to plug up vs. what to use before I build the tank back in.
Fargo
ID:	368583   Click image for larger version
fargotheAS is offline   Reply With Quote
Old 05-24-2020, 07:15 AM   #2
1967 28' Ambassador
to be clear which hole i'm talking about
second photo, right side of the photo (on the side of the tank)
Old 05-24-2020, 08:43 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Having a drain into the holding tank or a vent out of the tank from the side will definitely limit the capacity of the tank. Plus, that can be a good spot for a blockage to form in a horizontal pipe there. We would block that hole.
Chris and Kay
Old 05-24-2020, 03:16 PM   #4
1967 28' Ambassador
Thanks guys. Yeah, I'm gonna plug it up.
Old 05-24-2020, 03:22 PM   #5
2020 Classic 33
Box Elder , South Dakota
Where is your tank dump connection? Hope that isn't it since it would leave stuff in the bottom of the tank.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 05-25-2020, 11:46 AM   #6
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Chris and Kay
I agree about the vent needing to be on top, but why can't something drain into a gray tank from the side? If you read Vintage Trailer Supplies Advice for Designing Custom Polyethylene Holding Tanks they state:
"Inlet fittings on gray tanks are often on top. But they can be on the side, too. It doesn’t really matter. If your inlet is on the top of the tank, you can use it as a vent as well by teeing off of the inlet pipe between the sink trap and the gray tank. If you do not have an inlet on top, you must have a separate vent on top."
As long as you have a vent on the top, a drain into the side will still work. The water will just back up into the drain a little, but its level will match the level of the tank, which will still be below the level of your drain.
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
1965 Avion C-10 Truck Camper (65avion.home.blog)
DavidsonOverlander is offline   Reply With Quote
gray water tank - does it really need a vent? FlyingCloud3 Waste Systems, Tanks & Totes 17 10-16-2020 08:25 PM
Keep gray tanks from sliding side-to-side mashburn.nick Waste Systems, Tanks & Totes 4 05-22-2018 01:26 PM
Tank vent from side of tank? Jeremy9107 Waste Systems, Tanks & Totes 1 05-07-2018 05:44 AM
?s on outfitting outlet/inlet/vent fixtures on gray tank... PA BAMBI II Waste Systems, Tanks & Totes 0 03-30-2017 01:48 PM
Gray tank vent Dingo Girl Waste Systems, Tanks & Totes 3 04-28-2014 03:57 AM
