Old 10-11-2021, 10:45 PM   #1
Amherst , Massachusetts
Sewer Inlet Insulation
I'm installing a sewer hookup on my property to be able to use my Airstream as a guest house when we're not on the road. I'm in New England and want to have it available year round, including grey water out.
I intend to use PVC pipe wrapped in heat tape and insulation for the run from the trailer to the inlet. I think this is common practice and I've had success with similar setups in the past.
My question comes with the design of end the sewer line I'm installing to connect to my septic system. Is it enough for the opening to be even with ground level as long as it immediately drops vertically below the frost line, say 3'?
Code:
Or should I have the pipe terminate below ground level in some sort of box which can be insulated?
Code:
JoeStream is offline   Reply With Quote
Old 10-12-2021, 12:04 AM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Lots of sewer cleanouts have the cap slightly above ground. It doesn't matter as far as winter goes because the water doesn't stand in the pipe.
A good reason to put the cleanout slightly below grade in a concrete, metal or plastic box is so it won't be damaged by lawn equipment or if you drive over it.
CRH is offline   Reply With Quote
Old 10-12-2021, 11:33 AM   #3
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
The box is more initial work, but has multiple advantages: cleaner look above grade (and easier to mow over if it's in the grass), easier to access pvc for repairs, you can store a flexible hook up hose in the box (in the ground), etc.
kidjedi is offline   Reply With Quote
Old 10-15-2021, 08:56 PM   #4
Thanks you both for your advice. So I’m not going to worry about freezing, but I’ll consider a box anyway for the reason you cite. Cheers!
Old 10-15-2021, 09:06 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If you place the inlet below ground level it is possible for rain water to drain into the pipe. Depending on your location this could be a great amount of water. This could be a very big issue if you are on a septic system.
Richard
City water inlet and potable water inlet replacement sizing? LiamO86 Sprinter and B-van Forum 2 05-09-2019 05:05 PM
Used Marinco 30 amp inlet and Marinco Cable/Phone Inlet montanablue Airstream Classifieds 0 11-16-2018 03:09 PM
Moving City Water Inlet away from Sewer Pipe VintageFan Plumbing - Systems & Fixtures 1 10-19-2017 08:58 AM
Furrion Stainless Steel 30A inlet and TV inlet Gsmblue Electrical - Systems, Generators, Batteries & Solar 4 07-27-2015 06:58 PM
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 12:16 PM
