The door ( round twist end cap ) to my 16' Sport, sewer hose holder only turns about 1/8 of an inch to close. Vibration while travel shook it loose and it cost $50 to replace the hose that fell out on the hyway. Whats with that?
You did good to pack that hose in and still get a 1/8 turn. More than I could do. My solution was to cut the hose down to "fit" a standard off the shelf hose.
__________________ FishByFly because I catch fish on a fly...
I assume they still use the same ones they were using on early years.
Yes, the actual locking is just a bit of a twist. But if you make sure all three(?) of the tabs are engaged, it's pretty secure. I think the biggest problem is when one of the tabs isn't locked in and it can vibrate off.
I hadn't opened mine in over a year until yesterday. I almost needed pliers to turn it. I sprayed silicone on it... I will probably lose my sewer hose going down the road today.
2017 Basecamp
2006 31' Classic
2008 25' International
Traverse City, San Diego
, Michigan
I've had four Airstreams, same problem on all. Some fit tight, some fit looser. Some that fit loose all of a sudden don't. If your at the dealer ask them if there is a looser fitting one to be had. Often I only get in a partial twist and it works. All part of the experience...
