12-13-2020, 09:59 AM
2021 22' Caravel
Minneapolis
, MN
Sewer Hose Doesn't Fit Back in Tube
Hello AS Community, this is my first post about our brand new 2021 Caravel 22FB. My wife and I couldn't be more excited to be a part of this community and explore the country. We are on our inaugural trip and hooked up water for the first time last night! I bought two 10' Camco sewer hoses that are connected and were stored below in the under carriage hose tube, it fit great. When packing up this morning I tried to push it back in and now it doesn't fit! Twisted, turned, jiggled, and pushed; it won't go back in. Fortunately we only flushed grey water through it. Am I missing something? How did it fit perfectly after purchase, but after a single use comes up about 2.5' short of fitting back in?
For the time being I've detached the link. 10' went back in the hose tube and the other 10' went in the bumper compartment. I'm a little nervous about this though when we actually flush the black tank. Any advice or have others run into this?
12-13-2020, 10:18 AM
2019 16' Sport
Nelson
, British Columbia
Yes the slinky seems to get longer after one use and is reluctant to return to its layer.
I now use a Rhino slinky. It snaps into a short version of itself for storage. Also, it extends to just the needed length so you don't end up with a extra corners and twists that impede flow.
Recommended.
https://www.canadiantire.ca/en/pdp/r...8312p.html#srp
Scott
12-13-2020, 10:22 AM
2021 27' International
Carrollton
Do you have end-caps on the hoses? if so, air pressure inside will prevent them from fully collapsing.
12-13-2020, 10:27 AM
Tampa
I had that problem with the Thetford hose. Green and black?
I got so frustrated with an expensive hose that refused to slinky down after one use, that I donated it at a dump station!
Now I went with the Camco Rhino-flex and no problems going back to accordion. Rather than push on one end, see if you can collapse it a foot at a time. I made some devices of 1/2" PVC. I'm thinking of redoing them to use the caps included, then they'd fit in the tube. Obviously, one end has to unscrew, but there's PVC fittings like Legos.
12-13-2020, 01:36 PM
2019 27' International
Western NC
, North Carolina
Odds are this is the issue, my trick is to push into the tube with one end cap loose so air can escape, until it’s far enough in so you can put the tube end cap on, pull out slightly and lock the hose end cap. Then put on tube end cap.
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
12-13-2020, 04:24 PM
Tampa
So far I've avoided the end caps because I like the hose drying out with air flow.
I'm afraid I'd find a science project inside if left wet.
12-13-2020, 07:21 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
I find 10’ of slinky is adequate for every site I have stayed at, but keep the second 10’ section as a spare.
Ray B.
12-14-2020, 09:53 AM
2020 16' Caravel
Dayton
, Ohio
I find with our 2020 Caravel that the Viper RV hose (2 10' sections) must be coupled (connected sections) and that I have to be very firm pushing with the cover cap aligned properly to get a secure closure.-- really firm. Other hoses without swiveling ends work better for storage but not necessarily for the disposal process. I do not use end caps. Love our Caravel also. Have fun!
12-14-2020, 10:06 AM
SipStreamer
2010 20' Flying Cloud
Lakeside
, Montana
As to not wanting a poopy hose, ALWAYS dump the grey tank AFTER the black tank.
12-14-2020, 10:54 AM
2016 30' International
Quartz Hill
I have a Rhino Flex 15 foot. I store mine in the bumper compartment.
Yes, always dump the black water tank first. Then flush the black tank. Follow up by dumping the gray water.
Welcome to the community
12-14-2020, 12:40 PM
Western NC
, North Carolina
We used to do that and kept the extra 10ft hose in tube think we used it once maybe twice in a year. Then added and extra tube for the 15 freed up the rear bumper storage. [emoji106]
12-14-2020, 02:20 PM
2017 23' Flying Cloud
Port Richey
Sewer hose
After use, the sewer hoses tend to stretch a bit. We can only fit a 10’ sewer hose in our underbelly compartment and store a 15’ in the bumper. After a good flush and end caps in place you won’t have to worry about spills.
12-14-2020, 03:20 PM
2019 19' Flying Cloud
Canyon Country
I bought Camco RhinoFlex 20' kit from Amazon...
I flush out black water first then grey water. Then I flush out again with clean water, then its mostly cleaned out. I put end caps on both hoses and put them in bumper storage. It doesn't leak in the bumper because of the caps.
I love the RhinoFlex hoses, you can press both ends to make it down to 3 feet, when needed, you can extend the hose to full 10'. I had to use both at one campground everytime I go there. I threw away the previous owner's hose, it was not a good one.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
12-14-2020, 07:33 PM
2014 25' FB Flying Cloud
Fitchburg
, Wisconsin
Is the exterior of the hose clean? I had this problem once. It was caused by sand preventing full hose compression.
12-14-2020, 08:36 PM
2022 20' Basecamp
1968 17' Caravel
Los Osos
I've added tubes to my 25FB. Camping World sells them. https://www.campingworld.com/adjusta...ports-carriers.
They can be pop riveted to the underbelly supports on one side and to the pan on the other side of the tube mount tabs.. I carry two flex hoses and three black tank flush/grey water drain hoses. A fourth tube is perfect for fishing rods.
12-15-2020, 12:28 PM
Canyon Country
Yes as long as you do not spill anything out of the hose. I clean the hose with clean water, it is not slow moving water but more like rapid moving water through inside the hose.
12-20-2020, 12:35 PM
2017 22' Sport
Renton
Grandkids
When we finish with the hose we just toss it in the back seat and let the grandkids play with it during the long rides home. They end up playing telephone with it or running a ping pong ball back and forth through it. Keeps them entertained and it is way cheaper than an IPAD.
12-20-2020, 02:04 PM
Brook Park
, Ohio
No-go Camco
I don’t by any Camco junk. Problem solved. And avoid anything that is “new” or “improved.” It’s a dump hose. Nice shiny orange connectors doesn’t mean it will work better, store better or last longer.
12-20-2020, 03:20 PM
2020 27' Globetrotter
STAMFORD
, Connecticut
Get a urine-diverting composting toilet, such as a C-Head https://www.c-head.com/
You’ll never have to deal with sewage again.
The black tank in my Airstream Globetrotter has NEVER seen any sewage.
I’ve never had to deal with a stinky slinky.
12-20-2020, 04:58 PM
2019 27' Globetrotter
Litchfield Park
You still have to dump your gray water, so you still have to deal with a sewer hose (and a dump station), which is what the post is about.
Steve
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4WD LT
