Old 01-17-2023, 02:25 PM   #1
Streamer77's Avatar
1977 31' Excella 500
Duluth , Georgia
Sewer extension under Airstream
Is there some way to extend the sewer connector attached to the Airstream so it extends to the exterior of the trailer? I have to lay flat on the ground to hook up my sewer hose to the trailer as it is so far back and under the trailer. I am getting too old for this! Thank you.
Streamer77 is offline   Reply With Quote
Old 01-17-2023, 03:00 PM   #2
Escape Pod II
John Ware's Avatar
2022 23' Flying Cloud
2018 22' Sport
Orange , Texas
Can you post a picture or two of what you have to work with? They use ABS piping.
JEWare
John Ware is offline   Reply With Quote
Old 01-17-2023, 03:01 PM   #3
r3z
Los Angeles , California
Would something like this help ?
Camco 39050 Ready-to-Use Gate Valve with Built-in Clear Adapter, Black https://a.co/d/1rKxoxE
r3z is offline   Reply With Quote
Old 01-17-2023, 03:11 PM   #4
4RXLA's Avatar
West Sacramento , California
Images: 33
Looks like you have a ‘77 mid bath. I have a ‘77 rear bath and know what you mean as you pretty much have to get on your hands and knees to connect the sewer hose. The risk with extending the outlet for the rear bath is breaking it when the rear of the trailer drags on a driveway escarpment. On the mid bath, damage from a tire blowout or tread separation with slapping tread. The 70s trailers with mid bath have the sewer outlets less exposed to protect from blowout damage but make them harder to access. Your best bet may be to install a lift kit and/or replace the axles to raise the trailer a few inches to make it easier to access.
4RXLA is offline   Reply With Quote
Old 01-18-2023, 09:01 AM   #5
Mollysdad's Avatar
On mine, the "release" handles are on either side of the dump outlet. So the handle of the adapter would have to point straight down. That seems a road hazard.
On mine, it's awkward but doable to reach the outlet. To make it easier I replaced the cap with one having a built in handle;
and then added a clear extension to my sewer hose. Just to gain something to hold on to as I twist it on.
I never thought the 3/4" hose fitting on the cap was handy until I wondered how I could add a lubricant to the gate valve. A hose and funnel above the floor level would fill the drain fitting with lubricant, and you could exercise the valve without draining the tank. Then lower the hose end to empty the fitting before removing the cap.
Old 01-18-2023, 10:08 AM   #6
1967 17' Caravel
2000 31' Excella
Mukilteo , Washington
We had to install an external gate valve on our 1999 31’ Excella when the original black tank valve started leaking… It’s a Camco. The trailer is a permanent installation, otherwise I’d be compelled to remove it for travel. Anyways, it works flawlessly.
Luna1967 is offline   Reply With Quote
Old 01-18-2023, 11:24 AM   #7
lemley's Avatar
1988 29' Excella
Lorena , Texas
Camco 5” extender
I use this when I’m using my Sewer Solution. If 5” is enough then you might try it.
Camco Mfg 39573 Clear Sewer Hose Adapter 5"
lemley is offline   Reply With Quote
Old 01-18-2023, 06:41 PM   #8
1975 31' Sovereign
West Liberty , Kentucky
Sewer extender
I had the same problem with my 1975 center bath. Jackson Center extended the sewer pipe and the handles to a much better posityion much like latrer models.
Air4563 is offline   Reply With Quote
Old 01-19-2023, 08:40 AM   #9
Mollysdad's Avatar
Be aware that putting a external gate valve on the sewer fitting can comingle the grey and black tanks, if both handles are opened together, or one valve leaks while the other is open.
I'd rather not have the black contents finding it's way to the grey tank.
Driveway or residential power, water, sewer extension kit. stewartprice Airstream Classifieds 0 06-22-2019 05:14 PM
Sewer Solution Extension Question Jfuller678 Waste Systems, Tanks & Totes 12 11-03-2018 11:28 PM
Sewer Solution 10' extension hose. Will_Brule Waste Systems, Tanks & Totes 1 09-07-2013 04:55 PM
