Old 05-06-2017, 10:52 PM   #1
1977 Argosy Minuet 6.0 Metre
Cody , Wyoming
Sewage drain cap
Hello. Last year, the cap that goes over the exit drain under my 1977 Argosy Minuet fell off. It was in bad shape, anyway, so I didn't worry much. This year, I wanted to replace it.
I ordered one from Amazon - with the garden hose fitting attached - and promptly discovered that it is too small. It's 3 inch, but it looks like it would need to be 3 1/4 to fit my trailer.
I've searched amazon, vintage trailer sites, Airstream sites, ebay, etc. and can't find what I need anywhere. I can't even find an adapter so I can use 3" fittings.
Does anybody out there have any solutions for this?
0to60 is offline   Reply With Quote
Old 05-06-2017, 10:56 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Did your order a Valterra cap, but needed a Thetford?
CRH is offline   Reply With Quote
Old 05-06-2017, 11:04 PM   #3
Cody , Wyoming
Maybe so. This is the one I ordered:
It's apparently a Duraflex, but it's not marked.
Old 05-07-2017, 02:25 AM   #4
Mantua , Ohio
Yes, two sizes available..
Old 05-07-2017, 03:53 AM   #5
1977 25' Tradewind
Florence , South Carolina
I have a 1977 Tradewind so yours is probably similar to mine. Here's what I needed:
An adaptor/transition from the Thetford size to the Valterra size. Then you can use the cap that you already have. Here's the link:
http://amzn.to/2qORS83
The sewer connection on the 77's are sized for Thetford caps and hoses but the "standard" size is Valterra. Using this adaptor will allow you to use standard accessories with your trailer.
Since learning this (I had to learn this the hard way while on the road) I just keep a spare adaptor in the camper. Will probably never need it, but for an extra $10 it is worth it for my peace of mind.
I hope this helps! Happy Streaming!
ajcannon is offline   Reply With Quote
Old 05-07-2017, 06:04 AM   #6
Chelsea , Maine
I would get the adapter and glue it on.
2023 Entegra Odyssey 26M
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 05-07-2017, 09:56 AM   #7
Cody , Wyoming
Placed the order
Thank you all so very much!
I thought it was a problem that might not be solvable. I appreciate your quick response and Amazon should have the adapter to me in plenty of time.
Take care and have a wonderful Summer.
Pickup truck cap or no cap? weber.roger Airstream Lifestyle 28 12-04-2015 06:22 AM
Elbow Joint From Sewage To Drain Hose on '62 Tradewind ABomb1 Waste Systems, Tanks & Totes 2 06-04-2014 12:33 AM
Sewage drain valves leak shackman Waste Systems, Tanks & Totes 1 06-14-2013 01:28 PM
PVC cap for sewerage drain pipe phcpa Waste Systems, Tanks & Totes 3 10-04-2011 05:08 PM
Sewage/Termination Cap 1963 Globetrotter ShinyTiny Waste Systems, Tanks & Totes 7 03-09-2005 07:33 PM
