Old 04-12-2017, 08:27 AM   #21
2016 19' Flying Cloud
To add to the confusion, my 2016 FC manual also refers to them as the main holding tank (black) and the auxiliary holding tank (gray). I'll have to look at my decals.
ATownTX is offline   Reply With Quote
Old 04-12-2017, 09:57 AM   #22
Mollysdad's Avatar
Originally Posted by AWCHIEF View Post
More of the lack of attention to detail pervasive in at Airstream from the top to the bottom. Consumers need to be more demanding and stop letting these things slide before exceptance of the product.
As long as customers continue to plop down 3 X the $ of a boxy travel trailer, do you really think management cares? Or Thor?
(I'd also consider that the guy putting the labels on might not speak English!)
Originally Posted by avionstream View Post
This is such a nonissue. After the first use one should know which is which. Either remember which is which or relabel. One time issue.
Thor thanks you. QC not important.
Old 04-12-2017, 10:06 AM   #23
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
GVA , British Columbia
yah how dumb is that
I have to stop and think, my tanks are labeled Main and Auxiliary, and all you see are the pull handles on my unit. At least they have them labeled as they should be but the manual writers have not caught up to the change yet. Dysfunctional management style, maybe one day they will get it right or not.
I think I will relabel my black "shitty".
Laurence
LAWBC is offline   Reply With Quote
Old 04-12-2017, 11:22 AM   #24
On my 2016 FC 19 it's all labeled correctly and the handles for the valves are the correct but the pipes are reversed from the OP's AS.
Old 04-12-2017, 11:56 AM   #25
Mollysdad's Avatar
Probably due to the interior layout and location of the tanks.
Old 04-12-2017, 12:30 PM   #26
2008 19' Bambi
Carlsbad , California
Maybe just remove the labels and remember to dump solid waste (big pipe) first, and liquid waste (small pipe) second. The wording on the labels is confusing at best. Main tank, aux tank? Waste vs sewage? Just put a "Dump me first" on the black one.
Hijack:
Another place with conflicting confusing labels. Fresh water inlet directly above black tank flush with a label in between. You could assume the label is for the flush, but the inlet casting for the flush has "water inlet only" cast into it?
Russ
Ruscal is offline   Reply With Quote
Old 04-12-2017, 01:03 PM   #27
Yes I have a rear bath. But I can see how someone could get sticker happy and just apply the decal as they did for the last trailer.
Old 04-12-2017, 01:07 PM   #28
blackdog06
Blackdog06's Avatar
2017 25' Flying Cloud
2015 23' Flying Cloud
Tuttle , Oklahoma
Not to hijack, but interestingly our new trailer didn't come with a THOR sticker either. That was the first one I had planned to remove!
Blackdog06 is offline   Reply With Quote
Old 04-12-2017, 05:16 PM   #29
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
THAT'S why I painted the handle, Grey!
MelGoddard is offline   Reply With Quote
Old 04-13-2017, 05:31 AM   #30
2011 30' Flying Cloud
Greenback , Tennessee
Me Too!
As others have said, this is not a new problem. My 2011 AS has the stickers bassackwards too. I remedied it with a magic marker. I thought mine was the only one. I wonder if this is just a Monday morning hangover problem, or if the "sticker man" has been wandering around Jackson Center for years!
Gneiss Guy is offline   Reply With Quote
Old 04-13-2017, 05:47 PM   #31
Originally Posted by TG Twinkie View Post
My question would be. Why wasn't this caught at the dealer?
Don't be NAIVE!
Old 04-16-2017, 07:33 PM   #32
Originally Posted by Adventure.AS View Post
The handles (as shown in the photo) are correctly coloured, just the labels are reversed.
Both of my handles were black.
Old 04-16-2017, 07:38 PM   #33
Just use good judgement, because;
"Good judgement is learned from experience".
"Experience is learned from bad judgement."
Transport Canada posting.
Old 04-17-2017, 06:56 AM   #34
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Well all this sewer talk got me thinking about whether my new AS was also messed up. We got ours about 4 months ago new from the factory.
Happy to report that the sticker guy must have either been sober or trained by now. Stickers in correct location and color coded handles correct:
Troutboy
Troutboy is offline   Reply With Quote
Old 04-17-2017, 08:05 AM   #35
2010 25' FB Flying Cloud
Davenport , Iowa
Mine came WITHOUT labels or color coded handles; deal with it. I bought a clear elbow and figured it out. You bought an A$$ and they are fix it yourself units. There are leaks, tank indicators, tires, doors, drawers and the list goes on. One either fixes or takes time to go to the dealer or JC.
GOOD OLD/NEW AIRSTREAM
MJ
Airtandem is offline   Reply With Quote
Old 04-17-2017, 04:17 PM   #36
MJ
Like I said earlier; Airstream marches to their own drummer!
Old 04-17-2017, 04:32 PM   #37
Davenport , Iowa
But they don't have a rhythm or beat and have 2 left feet.
mj
Old 04-19-2017, 08:44 PM   #38
mj
Old 04-26-2017, 07:57 PM   #39
Paint the Grey Handle Grey, or white.
Old 04-26-2017, 10:37 PM   #40
I'll paint it Zane Gray
Can I/Should I Remove Screen on Water Inflow to Wastewater Tanks? Kellycanoe Waste Systems, Tanks & Totes 9 07-21-2015 07:28 PM
Adding wastewater-tank to Bambi 422 Felix Salten Waste Systems, Tanks & Totes 0 09-14-2013 02:53 PM
Help: Size of wastewater tank?!!! fallon Waste Systems, Tanks & Totes 5 03-08-2011 02:08 PM
Wastewater System rrg Waste Systems, Tanks & Totes 0 01-02-2010 07:39 PM
Heat pump switched on in AC mode Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-22-2005 08:09 PM
