11-21-2021, 10:04 AM
33’ Classic 2018FB
2018 33' Classic
Colorado Springs
Sewage
My partner insists that the black tank should be closed to outside sewer in RV park. And then once a week or so he will be empty tank. I find it odoriferous. Why not keep tank continually flowing into outside sewer???? 33’ 2018 Classic Airstream
11-21-2021, 10:10 AM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
If you leave it open continuously, you may find that the liquid has drained, leaving you with the dread "brown mountain" directly under your throne.
Black tanks work best when there is a lot to flush at one time. Then follow that with your gray water.
Happy travels.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
11-21-2021, 10:15 AM
2002 25' Safari
Dewey
Your partner is correct. By keeping the valve closed and dumping when the talk is full will ensure that the solids are carried away with the liquids. By leaving the valve open you may have a build up od solids in the tank commonly referred to as the "Black Hills".
Also, keeping the valve open will allow fumes from the sewer system to work their way into you black tank and your trailer
Richard
11-21-2021, 10:20 AM
Riveted...?
2004 25' Safari
Central Valley
Both Az and PMC are right...recommend adding more deodorant in the interim and making sure the the toilet seal is intact...we recommend using the orange deodorant (TST) available at Wally world...
- Lots of people are engaging in risky behavior, but most of them just don't know how risky their behavior really is...
2013 Ram, 2500, Crew Cab, Cummins, 4x4, SRW, Short Box
2004 25', Safari LS w/ 3" Dexter Lift Kit on Henschen Axles,
Blue Ox
11-21-2021, 10:26 AM
Tampa
Make sure, as others said, your seal is holding water. I used to put a little olive oil in the bowl. Also, the roof vent can blow right back inside if your Fantastic Fan is nearby.
I never use the toilet for, ahem, solids or paper. So the last time I drained the tanks, I had a minute of blue water followed by two minutes of grey water. No lumps.
Beyond that, check this video by "Changing Lanes". He scrubs the vertical pipe under the flapper valve.
11-21-2021, 10:27 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Greetings from the Florida Panhandle
Your partner is absolutely correct! The number one rule of RV camping is NEVER EVER leave the black tank valve open except when actually draining the black tank. Leaving the black tank open will cause "black hills syndrome". This can result in having to replace the black tank. With the labor involved, it would cost several thousand dollars.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
11-21-2021, 10:28 AM
I'm In
, Kentucky
I would add, if you have the Fantastic Fan on, open the other vent or crack a window, otherwise you'll pull air from the holding tanks.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
11-21-2021, 11:54 AM
1986 31' Sovereign
Miami
Originally Posted by LEA777
We have a 2018 Classic FB 33’ . My camping partner insists
He keep the valve to the black tank closed even while we have full time hook up to outside sewer. Then when it’s close to full, he will dump it. Any logical reason to do it this way?
Signed,
Odiferous 🤢
As Moosetags pointed out, leaving the black tank valve open will result in the liquids draining off, leaving the solids to harden into stalagmites of immovable poo.
As an added bonus, you will be leaving a pathway open for sewer gas to enter your trailer as there are no “p” traps on RV toilets.
Best practice is to have the black tank full (or nearly full) when you pull that handle to dump as gravity and water are your friends.
Also good to have enough water in the gray tank to flush the sewer hose when you are done.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
11-22-2021, 05:40 AM
33’ Classic 2018FB
2018 33' Classic
Colorado Springs
Thank you much. That makes sense .
11-22-2021, 05:52 AM
Evergreen
You might consider a different tank treatment than what you’ve been using If tank odor is a problem. I found that tank pods and deodorizers aren’t very effective. Last year I switched to Happy Camper powder tank treatment, and it is much better than anything I’ve ever used. We have virtually no tank odors or problems.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
11-22-2021, 06:20 AM
2018 30' Classic
Thousand Oaks
Sewage
I’ll second the happy camper. We used the pods for one pack and switched to happy camper about 3 years ago. Haven’t used anything else since. We use the largest size to get best pricing but here is an affordable smaller option too.
https://www.amazon.com/gp/product/B0...36f532f4deaf7b
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
11-22-2021, 07:21 AM
2002 30' Classic S/O
Fleming Island
I use TankTechs Rx. IT does a great job. No odors if directions followed.
11-27-2021, 08:35 AM
2023 27' Globetrotter
Charlotte
, North Carolina
Happy camper is our go-to as well. 2.5 years and no odors.
I also use a 1/2 cup of dawn dish detergent and 1/2 cup of Calgon water softener after everything dump & flush.
11-27-2021, 09:29 PM
2017 25' International
West Lake Hills
If I plan to drive to another site that has a dump station or sewer hookup, I leave some liquid in the tank to churn and dissolve the solids. Dump on the way in instead of on the way out. The black tank discharge looks almost like the gray after a hundred miles or so of sloshing.
11-28-2021, 04:19 AM
2009 25' FB International
2018 27' Globetrotter
Tavares
Another vote for Happy Camper!
11-28-2021, 09:34 AM
2019 25' Flying Cloud
Hendersonville
, North Carolina
Flushing black tank
I always drain black tank when at least 75% to 100% full. As it is draining I hook up my dedicated black tank flushing hose to the flush out port and turn on the water. Let it go couple of minutes. Close the blank tank drain valve and let tank refill with clean water to 75%. Open black tank drain valve and continue flushing until clean water comes out. Usually about 2 or 3 minutes. Close the blank tank drain valve and immediately turn off water. Nice clean tank ready to go again. Always keep black tank drain valve closed unless draining/flushing.
This has worked well for us for the past 4 years. We use the orange TST stuff from CW and no odor problems. I do lube the commode seal.
Nothing worse than the Black Mountain in the black tank.
12-01-2021, 09:29 AM
2012 27' FB Classic
Boise
, Idaho
In addition to the "Happy Camper", which is the best IMO, I would suggest stocking some CALGON LIQUID water softener in your supplies and adding a capful at the some time as the Happy Camper. Not a large expense, and one that I trust.
12-01-2021, 09:37 AM
Lake George
Ahh, the dreaded Pyramid of Poop threat! Nice couple with three little ones spent two or three weeks next to us some years back. A day before they were to break camp they had what he described as a disgusting IED loaded with recent meals. It seems they had left their black tank valves open on two previous weekend camping trips in their new RV. It was pretty nice. I felt so sorry for them. They spent the rest of that day and all of the next cleaning it up and left nearly the middle of the night.
12-01-2021, 09:49 AM
2006 34' Classic S/O
1994 28' Excella
1950 19' Globetrotter
Elgin
Open black/gray handles = sewer bugs
Not previously mentioned is the fact many/most private CGs are run on a septic system. The perfect breeding ground for tiny flying "sewer bugs".
I see this all the time when I remove the sewer cap in preparation to stabbing my sewer hose & a host of them fly out. Yuck!
These obnoxious little creatures will fly up your dry sewer hose and take up residence in your black/gray tanks if the valve is in the always open position. Then when your partner flushes the toilet 🚻 they fly into your rig. Then they hide behind curtains. Get into tiny spaces. And reproduce ad-nauseum and are generally a nuisance and hard to get rid of.
Not a problem for the gray water tank since all it's drain sources have P traps preventing entry.
At the end the day I'm in agreement with all of the reasons mentioned by earlier posters but offer this additional cautionary warning ⚠️.
12-01-2021, 09:58 AM
2017 Interstate Grand Tour Ext
CANON CITY
We leave the tank open, and form a goose neck in the drain hose …
