Old 04-17-2018, 06:52 AM   #1
1978 31' Sovereign
Brooklyn , New York
Separating grey and black water
Boon-docking on my property with a 78 Sovereign. Contemplating getting a composting toilet eventually, but just looking for an interim solution. I was thinking about trying to isolate the black water system from the grey water system and hooking up a tote to the directly to the black water outlet, and just letting the grey water filter through a sand system ( I would place the appropriate grease traps etc. ) had anyone had any experience trying to do something like this? I would prefer not to use the blackwater tank at all, and just have it exit straight to the external tote, I would then dump the tote later at a dump station or into a friends septic system.
estock is offline   Reply With Quote
Old 04-17-2018, 07:30 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have a Blueboy that has an attachment which hooks over the ball on your hitch so you can tow your stuff to the dump station. Take it real slow and make sure it is sealed well. Don't ask me how I know.
20 gallons+ of @#$% can get awful heavy.
Old 04-17-2018, 09:47 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
So, let me paraphrase back what I am hearing: You want to disconnect your grey water from the common dump valve, (I assume) add a second dump valve for the grey water only, which, when dumping, would drain through a filter system and then onto the ground. You want to attach the black tank dump valve directly to a tote and leave the valve open all the time so that black water never stores up in the tank, but goes immediately into the tote.
If the above is all correct, I would offer the following: You should be able to accomplish what you want to do without disturbing your existing plumbing, assuming that original common dump valve has a valve for the black tank and one for the grey. You really don't want to leave that black tank valve open all the time--you want some fluid in the bottom of the tank, and to let it fill up until it is ready to dump all in one go. If you leave the valve open all the time, you will very likely get an accumulation of solid material in your black tank.
Similarly, you would want to let your grey water tank fill up. You could then use the grey water as a flush of the hose going to the tote to help clean rinse away the black water. You could occasionally attach the hose comeing from the dump valve to your sand filter and dump the grey water as needed. If you don't want to hassle with moving the connection around, and you want the grey water to drain continuously, then you will have to separate the dump valves.
good luck!
Replacing black/grey with a larger grey whitney Waste Systems, Tanks & Totes 11 05-08-2012 06:47 PM
Awning separating from camper BeckyAnt Awnings 14 08-22-2010 09:24 PM
Compartment trim separating jottie77 General Repair Forum 2 07-19-2010 06:09 PM
1968 Type 3 window hinge not separating twisteda Windows & Screens 7 10-25-2008 09:25 PM
Bumper Separating from Shell--Help! Laure&Chuck Bumpers & Bumper Storage 11 11-07-2004 02:25 PM
