Old 09-01-2008, 10:19 AM   #1
2016 30' Classic
Columbus , Ohio
Sealant coming off flange pipe transition to tank
I was looking down my toilet and saw some tp hung up on something. Used a stick to dislodge and noticed it was hung up on a loop of caulk that was almost detatched. The toilet in my 05 Safari is raised on a box. The flange assembly has a black pipe that goes straight down about 8 inches and it appears to terminate inside a wider tube slanting down to the tank. This is where the caulk is. Using a mirror and flashlight, I looked the "transition" from underneath and saw a grey, seemingly flexible seal to close the gap between the pipes - like a telescope as if to promote movement. The caulk was apparently put there to cover that gap, but is now 90% pulled away.
I am hoping someone could explain this design and provide their opinions whether or not I need to remedy or leave be. I suspect that grey seal is designed to do a job and the caulk might possibly be redundant.
I removed some 8 screws holding the flange to the floor, but was unable to budge it. Not sure how that comes out as well.
Thanks!
2016 Classic
2016 Ford F-250 Lariat 6.7PSD
jeff4506 is offline   Reply With Quote
Old 09-08-2008, 04:23 PM   #2
2016 30' Classic
Columbus , Ohio
Let me ask this - does anyone know what pipe connectors would be used to connect the flange pipe to the tank? Again, the pipe going down seems to be an inch or so less in diameter than the elbow it's connected to. That gap had caulk in it, and it seemed to be covering a seal of some sort.
2016 Classic
Blackwater tank flange bilby05 Waste Systems, Tanks & Totes 20 10-31-2014 09:40 AM
How to Remove Toilet Flange from Waste Tank? monocoque Waste Systems, Tanks & Totes 15 06-10-2013 06:41 PM
Glue or clamp flange to black tank? pilgrim_still Waste Systems, Tanks & Totes 12 03-11-2010 07:08 PM
broken flange on blackwater tank? 1971 vintagemike Waste Systems, Tanks & Totes 13 12-14-2007 07:04 PM
Need flange for my toilet-b/w tank 68Glbtrotter Waste Systems, Tanks & Totes 7 01-24-2006 08:07 PM
