Old 05-06-2023, 09:08 AM   #1
2020 27' Globetrotter
WOODWAY , TX
Rhino Waste Water Totes
Didn't see a better place to ask this question on the air forum, so here it is. On the newer Rhino waste totes, the towing handle connects to the Tote with a pin that uses a spring loaded ball bearing to keep the handle attached to the tote when in use. Have not had the opportunity to tow it with 36 gallons of liquid yet. But, as that is around 200 lbs. of gray or black water, I am concerned. Has anyone had this disconnect while being towed due to the pin coming detached? I imagine this crashing into someone campsite would at the least be upsetting if not creating a nasty cleanup job.
Paul Canaris is offline   Reply With Quote
Old 05-06-2023, 10:05 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Totes should be towed at walking speed, 4 MPH.
Richard
azflycaster is online now   Reply With Quote
Camco Rhino Portable RV Waste Holding Tank with Hose and Accessories, 21 Gallons, Gray - California Richardcolin Airstream Classifieds 0 08-20-2022 02:05 PM
28 gallon Rhino portable waste water tank 1590Denny Waste Systems, Tanks & Totes 1 05-18-2020 02:41 PM
Those blue totes - opinions / reccommendations sigv Waste Systems, Tanks & Totes 14 03-11-2008 02:22 PM
Sewer Totes jcanavera Plumbing - Systems & Fixtures 37 09-22-2007 07:51 PM
Totes versus Gray Tank Tom Bray Waste Systems, Tanks & Totes 17 09-17-2007 06:03 PM
