Old 05-16-2021, 05:31 AM   #21
1966 17' Caravel
Pine Plains , NY
Dear all, thank you for your suggestions, ideas and cautionary tales. I live in upstate NY where the Board of Health (who oversees septic installs) rules the roost. Because I live on a state-protected lake, the solution needs to be by the book. I did call my septic person first…and was told they had never heard of such a thing. Hmmm. Now that I am armed with the proper vocabulary, I may get further. But first, I want to see if I can locate a clean out in the line. I know where it is inside, but I do not recall seeing one outside or anywhere near the septic manhole cover.
I like Bob and Richard’s idea of seeing if I can install one that is integrated with the existing system. I have a great plumber who will know what is and is not possible and whether it would interfere with the “biology” of my septic holding tank (thank you for that info, Richard). If you could see my property, and the location of the lake, well, you would understand that this needs to be considered and installed carefully.
Again, thanks everyone. I am very grateful for the knowledge base on these forums, and will update this page once I have a viable solution in case there is someone else who would like to retrofit a septic system. Flostream66
Flostream66
WBCCI #4597
VAC Region 2
Restoration of my 1966 Caravel: https://www.airforums.com/forums/f13...on-210688.html
Start at Post #7.
Flostream66 is offline   Reply With Quote
Old 05-16-2021, 07:13 AM   #22
rideair's Avatar
Flostream66,
Since you're in the state of New York, you might want to give these guys a try.
https://certifiedcesspool.com/Cesspo...Island-NY.html
Eighty year technology, brought up to todays standards ;-)
Just Saying,
Paul Waddell
rideair is offline   Reply With Quote
Old 05-16-2021, 08:06 AM   #23
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
The "big bunch of rocks in a pit" approach may be legit for gray water. It's not going to be even remotely legal for black water. I have seen folks put in a setup like this to dump the output of their cloths washer into. We looked into it a while back. There didn't seem to be a major issue getting a permit for it.
Even if the pit *was* legal, I'd bet at least a six pack that putting a clean out on the existing setup will be cheaper than digging the pit and doing all that work.
Old 05-16-2021, 08:32 AM   #24
rideair's Avatar
uncle_bob,
Yes, a "Dry-Well" is one of the best things a person can install at their house if they live on a septic system to help keep the septic system alive and well. Gray water is what kills the standard "septic-tank, drain-field" system, then adding olive-oil when washing dishes (stays suspended in the water, clogging the drain-field) to the mix, and you're done. If you could build your house where the toilet water goes to one system, all gray water (shower/sink/laundry) to another, it would be far better for the environment and waste-systems would last much longer.
Just Saying,
Paul Waddell
Old 05-16-2021, 08:39 AM   #25
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
Originally Posted by bweybright View Post
HUH? and what part of the boonies are you living (if you follow infection studies you will find it has not been safe for 80 years....)? Not to mention stupid...do you want to pollute your shallow well (from 80 years ago) if you are even thinking this? Oh, wait I get it - you are making a joke and we took your post for being serious.
Groundwater conditions and regulations vary dramatically throughout the country/world. There are many places where where a simple drain field septic system would be perfectly sufficient, safe and legal. Don't assume that the conditions or regulations at your house apply everywhere. I'm a hydrologist and I've designed numerous systems like this.
Thalweg is offline   Reply With Quote
Old 05-16-2021, 03:28 PM   #26
2020 27' Flying Cloud
Howell , MI
We have plastic covers on our septic tanks. I removed the one closest to where the effluent enters from the house, drilled a hole in it, installed a garden hose fitting (with a plug/cap) and reinstalled the cover. We use a portable macerator pump with a larger diameter garden hose to empty the tanks if we arrive home with anything in them. Obviously (sic) we have different hoses for putting fresh water into the rig.
BandLAir is offline   Reply With Quote
Old 05-16-2021, 10:54 PM   #27
PC Conner's Avatar
2018 27' Flying Cloud
INDIAN HARBOUR BEACH , Florida
Great discussion.
I'm about to install/have installed a cleanout on a city sewer line.
I found this You Tube video <
PC Conner is offline   Reply With Quote
Old 05-17-2021, 05:28 AM   #28
2020 16' Caravel
PERRY , UT
Originally Posted by rideair View Post
You could always just dig a big round hole in the ground, place a layer of large stone in the bottom of the hole, place a metal 55 gallon drum with many 2" holes drilled in the side (or shot many time with the firearm of your choice), place drum in the hole placing large stones between the drum and the dirt wall, place a 4" pipe in the top of the drum to where it slightly rises above ground level, cover back over with dirt.
Not that the above is right/legal/etc... but it has worked for many years with no problems going back 80 years in the many hollows and hills of the USA. It was a poor mans septic system for the longest time.
Pretty sure it is not legal anymore but used to be common practice in places. And I know of people still doing it, mostly for laundry water disposal. The first "septic tank" I saw put in was in Wyoming 50+ years ago, an old car, the sewer pipe just ran in an open window. Very course gravel soil and it is probably still working today. But, in my opinion, not a very good idea.
alligatorob is offline   Reply With Quote
Old 05-17-2021, 06:19 PM   #29
2013 28' Flying Cloud
Penn Yan , New York
Septic with clean out
I live in upstate NY on a protected lake also.
I had the company that pumps out my septic tank install a clean out on the line from the house to the tank. Really simple. I dug down to the septic line which should not be too deep. I cleaned out enough dirt so they could cut the pipe and install a tee with a sweeping riser.
It took them about 15 minutes to hook it up.
I purchased a 25 gallon 4 wheel septic cart. I dump my Airstream tanks into the cart and pull the cart to the clean out. The clean out is just like most of the hook ups in rv parks.
This set up works great.
delrossa is offline   Reply With Quote
Old 05-17-2021, 06:45 PM   #30
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
Many homes in Mexico are still built with cesspools under the bathroom. Common practice is to take a section of large diameter concrete pipe like the kind used for culverts and place it vertically in the ground, then build the bathroom right over it. The bottom is not sealed so the liquids can leach into the earth. I have seen them just a stones throw from the beach. (We don't drink the water)
Brian
ITSNO60 is offline   Reply With Quote
Old 05-18-2021, 02:21 AM   #31
1966 17' Caravel
Pine Plains , NY
PVC vs ABS and 2-way vs single hole clean out
PCConnor, thanks for posting the YouTube video. It was instructive, and now I understand why my plumber prepared me for the "big hole" he said he is going to have to dig in my front yard...seems a small price to pay to avoid the long dump lines. So, I remain undeterred.
PC, I wanted to share the video which populated right after the one you shared: https://youtu.be/kzVePooP7BQ. The man in the video, Roger Wakefield, has a whole plumbing channel...oh, and snazzy plumbing background music and a big watch. :/
He used PVC, not ABS, to create an in-line clean out. He did not explain why; only that "its how we do it in North Texas." If you read the comments, it seems that the code on this varies widely, and depends upon whether the project is resi or commercial...just as an FYI for DIY'ers to check local codes.
Note also that the video uses a two-way clean out as opposed to a single port...can anyone explain why? Mr. Wakefield merely said that a two-way is the way to go. Seems like a single clean out might be better for home honeypot purposes. Anyone have a considered view on this? My plumber is coming later this week.
Thanks "y'all." Flostream66
Flostream66
WBCCI #4597
VAC Region 2
Start at Post #7.
Old 05-18-2021, 07:11 AM   #32
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
Well since you are using it as a dump it is not just a cleanout now and since you want the flow to be toward the septic I agree that a one way is the way to go as a two way may not start stuff moving in the right direction. BUT There are two ways to make a two way cleanout. there are two way cleanouts that are one piece but there are also two way cleanouts that are created by installing two one ways next to each other facing opposite directions. The one piece would not be desirable in your case but the latter, although more work and a bigger hole, would not affect dumping as long as you choose the downstream one to dump in and it would give you an upstream one if you ever need to clear the line to the house. Since you will be digging it up anyways this is the way I would go unless you already have a cleanout further up that would serve that section.
Brian
Old 05-18-2021, 09:45 AM   #33
1966 17' Caravel
Pine Plains , NY
Excellent suggestion, Brian, and I thank you for it. Will update as and when the job begins! Flostream66
Flostream66
WBCCI #4597
VAC Region 2
Start at Post #7.
Old 05-18-2021, 10:07 AM   #34
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
Here's a pic of the one piece 2 way and a pic of the two way built from 2 one ways that the plumber in your video built. You may want to mark or color the cap with arrows if you do the 2 piece because the proper one to use will be the one farthest from the septic, which is counter-intuitive to non-professionals.
ID:	395700   Click image for larger version
Brian
Old 05-18-2021, 01:21 PM   #35
1966 17' Caravel
Pine Plains , NY
Yes, I would have been "Flo-ing" in the wrong direction...thanks, Brian.
Flostream66
WBCCI #4597
VAC Region 2
Start at Post #7.
Old 05-19-2021, 10:21 AM   #36
2019 22' Sport
High River , Alberta
I have seen such a thing used on a municipal site, for the convenience of sewage sludge haulers who could dump right into a trunk sanitary sewer. RVers were free to use it too if they knew where it was and wanted to. (There was no water supply nearby for flushing.)
I think a welding shop could modify the manhole cover for you.
AlbertF is offline   Reply With Quote
Old 05-19-2021, 03:25 PM   #37
1966 17' Caravel
Pine Plains , NY
Hi Albert - I think the issue with dumping from above, as opposed to inline is the one raised above - namely that it might upset the bacteria levels...so for now, I am going to wait on the plumber to do the inspection and digging to unearth the pipeline to the septic...kind of like waiting for the Colonial Pipeline to gin back up!
Flostream66
WBCCI #4597
VAC Region 2
Start at Post #7.
Old 05-20-2021, 12:27 AM   #38
2019 22' Sport
I didn’t realize that your “manhole covers” were directly above the septic tank. Yes, you don’t want to stir up the sludge in the bottom of the septic tank. If these solids enter the tile field you’ll have a problem. It’s also important to have the tank pumped out before the sludge rises to the level of the effluent pipe.
Actually, I should correct what I wrote. The manhole I described is for septic tank sludge haulers to dump into. The pipe runs directly to the community’s wastewater treatment system.
Old 01-30-2023, 02:05 PM   #39
Centerport , New York
Thumbs up
Originally Posted by richandwanda View Post
Septic tanks [...] have baffles so the sewage enters the tank without roiling the contents. Dumping sewage directly through the tank lid may stir up the floating scum layer which could cause solids to get out of the tank and into the drain field.
Thanks for explaining clearly why dumping into the cleanout is preferable over dumping directly into the septic tank!
DonPayne is offline   Reply With Quote
Black water tank with septic system rfield54 Waste Systems, Tanks & Totes 5 06-02-2021 07:13 PM
Wanted: Blue Ox 9-hole or 11-hole shank Runamuk13 Hitches, Couplers & Balls 1 12-15-2020 01:18 PM
Any advice on using home septic to drain black water? Seattle206 Airstream Trailer Forums 43 12-26-2019 09:16 AM
Dump valve clearance on a retrofit 1965 Trade Wind Gray & Black Tanks Rocker66 Waste Systems, Tanks & Totes 6 04-23-2015 10:19 PM
Black water holding tank changes for using trailer as stationary home/external septic bol-gordon All Argosy Trailers 3 05-20-2009 07:34 AM
