There could be circumstances in which I might "live" in my AS while parked at home, or have a long term guest. It would be ideal if I could empty my AS black tank into my home septic tank. The problem is that the AS sits about 15-20 feet below grade of the septic tank cover. I was considering installing an external macerator pump to the black tank drain, but I can't find manufacture's specifications on how uphill these
12v units will push a column of water. From what I have read, 2.31 ft column of water creates 1 psi of pressure. So it looks like the pump would need to generate around 8 psi. Not that much.
Does anyone have insight to this situation or better math than me?
Gary
