Old 04-24-2017, 08:44 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
1961 24' Tradewind
Strasburg , Pennsylvania
Process for installing new closet flange on 1964 black tank
I am getting ready to install a new closet flange on top of my above-floor 1964 fiberglass black tank. The old flange is long gone (thrown out during renovation), but I believe it was screwed to the top of the tank. The screws were mostly gone and were ground flat when the tank was re-gelled.
Can I drill and tap the inset cast metal fitting for new screws to attach the new flange, or is it better to glue the new flange on?
I am really trying to find out if there is enough (total diameter) cast metal inset in the fiberglass to drill and tap. I believe the process will be straightforward enough if I can ascertain if there is enough metal there to do it.
Thanks for any advice or insights.
Ben
ID:	284080   Click image for larger version
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 05-12-2017, 07:55 PM   #2
1964 17' Bambi II
1961 24' Tradewind
Yes you can...
Cast fitting can be drilled and tapped. I drilled 5 holes and tapped 4. There was a spot where I only hit fiberglass when drilling...no cast iron.
black tank and toilet flange; when is it necessary to replace the tank? Globie64 Waste Systems, Tanks & Totes 7 09-07-2011 04:04 PM
Closet flange and new cork floor. desertair27 Sinks, Showers & Toilets 3 06-17-2011 04:10 PM
Black Tank-To Flange or not to Flange? Mrwaterway Waste Systems, Tanks & Totes 4 12-02-2009 09:02 AM
Closet Flange question jeffdales Waste Systems, Tanks & Totes 7 07-07-2008 09:58 AM
Closet Flange help! Please read and help! Roger2005 Plumbing - Systems & Fixtures 7 01-28-2006 05:40 PM
