Old 02-06-2020, 09:39 AM   #1
2019 25' Flying Cloud
West Windsor , Vermont
One cup
Hoping for some insight on this one. After emptying the black then gray tanks and securing the handles with supplied clips we hit the road. Next stop... ready to attach sewer hose and remove cap on outlet. About one cup of effluent, maybe gray maybe black or both will run out. I assume one or both valves are not closing completely. How would you fix this? Thanks
Peterf is offline   Reply With Quote
Old 02-06-2020, 10:27 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Likely this was residual waste left in the plumbing after dumping. Dumping grey tank after black tank should rinse out the bad stuff. You could also rinse the black tank if you have that capacity or let a couple of gallons of water in the black tank. and dump a 2nd time.
Old 02-06-2020, 10:32 AM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Many dump stations are level or sloped away from the drain. You could pull up onto a 2x4 on the passenger side to slope the system towards the drain.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 02-06-2020, 10:32 AM   #4
Mollysdad's Avatar
I had the same issue. I worried about it, but it hasn't happened again.
I chalked it up to trash in the tanks. I think I saw a tip from a tube of caulk. I suspect while under construction, the assembly line just throws junk in the toilet or sink. (common in home construction too)
So something kept the gate valve from closing, later flushed away.
EASY CHOCOLATE CAKE 1pan 1 fork 1 cup Airperson Stella's Kitchen 5 03-02-2010 09:18 PM
Bristol Motor Speedway Nextel Cup ZoominC6 On The Road... 20 03-28-2007 10:25 AM
Windshield Suction Cup Law rickandsandi Off Topic Forum 35 03-01-2007 09:25 PM
This interior may not be everyone's cup of tea but ... summerkid General Interior Topics 3 04-29-2004 01:14 PM
P Trap Cup Chitown AirStreamers Plumbing - Systems & Fixtures 2 07-29-2003 02:34 PM
