Old 05-09-2021, 06:42 AM   #1
2016 25' International
Gaffney , South Carolina
Need ID for gasket material found in BT flush
I found this gasket material when I flushed the black water tank using a hand wand. The dump valve on tank is not leaking so I think its possibly in the toilet stack and I've gouged it out from somewhere there. The top flush valve in the toilet stack seems to be intact with no unusual odor.
Is there a schematic drawing or some way to ID the replacement gasket I need, and
How big of a repair job am I looking at?
DT57 is offline   Reply With Quote
Old 05-09-2021, 06:50 AM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
DT57,
Greetings from sorta near the Track too Tough to Tame, AKA The Lady in Black, S.C. For the non NASCAR crowd that's Darlington and today is RACE DAY! Nope, I'm not going.
The grey stuff looks like Butyl sealant. I just used some last year on tank valve R&R. Not sure about the black, Silicone RTV??? I had a time finding that stuff, found it at an RV store as skylight sealant. It stays flexible a bit like used chewing gum.
But how about a slow fill test with clean water of the tank and see if it's an actual issue or left over from mfgr of unit?
Access to the no fuss flush likely means time to find it's general location then make an access hatch in the pan keeping in mind might as well make it big enough for valve service if ever needed.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 05-09-2021, 06:57 AM   #3
Yes this stuff is very flexible almost jello like. I'll try a tank fill and check for leaks. I have a camera scope too so will try that.
Thanks GC.
Old 05-09-2021, 07:57 AM   #4
GCinSC2's Avatar
That butyl is what seals the valve “stem” into the tank. It’s a slip fit with clamp. The butyl is the flexible sealant making it water tight. That might be excess that found daylight.
S/OS #001
Old 05-10-2021, 11:22 AM   #5
2020 27' Flying Cloud
I found the same sort of stuff, blocking my black tank valve.
https://www.airforums.com/forums/f44...on-210904.html
Brainodo is offline   Reply With Quote
Exterior gasket material? NicheVintage Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 01-31-2011 08:56 PM
Gasket Material for rib before installing Interior skin CapnTom Ribs, Skins & Rivets 13 01-19-2010 07:56 AM
Counter Top Gasket Material Tom Bray Cabinets, Counter Tops & Furnishings 9 04-25-2008 11:21 AM
Gasket Material for Kitchen Fan Cover bevman Roof Vents, Skylights & Fans 1 06-28-2007 07:39 PM
1968 Door gasket material Boondocker Doors & Locks 1 05-15-2007 07:34 AM
