09-25-2007, 08:37 PM
2007 25' Safari SS SE
Alton
Macerator pump
I have read about macerator pumps in articles about motorhomes--Is one of these pumps possible or better yet practical in an AS TT? Seems like Teche is a good brand--any thoughts or comments? Thanks, Brad
The "Ann Rutledge"
09-25-2007, 09:35 PM
I added a macerator pump on my '59 Tradewind. There are a couple of pictures in my photo gallery.
A couple of things to keep in mind:
1. Make sure you have an alternate way to dump if the pump breaks or the battery is dead.
2. Good idea to have a warm air duct to keep the pump warm during freezing weather. I installed a muffin fan and duct from the bathroom after the photos were taken.
3. I wired mine through a relay, then use a switch on a lanyard to operate the pump. I can stick the 3/4" hose in the "hole" with one hand and turn the pump on with the other. Quick, clean, and easy.
4. Consider adding a tank flusher while you are putting in the pump.
I think it's a great idea!
Regardless, some will say it's overkill.
09-29-2007, 03:09 PM
When it comes to Turd Wrestling nothing beats a macerator in the ring or outside of one. We always carry one when it’s time to blow the ballast in a hurry. Carry a one-inch hose from 50 feet or longer so you can reach a clean out at the outside of your house or some place else. Always a great tool to have when nothing else will rip and shred the real stuff people are made of.
09-29-2007, 05:53 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Not to hijack
But do you guys really have that big of a problem getting the waste to flow out of the tank? What am I missing?
09-29-2007, 06:15 PM
1967 26' Overlander
Huntsville
Originally Posted by Gen Disarray
...? What am I missing?
I use a portable macerator pump at my house since the Overlander is too far away from a 3-inch line to dump directly.
With our style of camping, there is no need to incorporate a macerator into the Airstream or carry it with us.
Tom
09-29-2007, 07:05 PM
2012 28' International
New Orleans
, Louisiana
Macerator pump the simple way.
Macerator pump the simple way. I glued a Macerator pump to a clear elbow using marine epoxy. When I want to use the pump I just connect it to the outlet instead of the dump hose. You will want to add a 12 volt cord to go to battery or run a connection to the dump area, please fuse appropriately. I use the pump to dump my tank to my home sewer system to a cleanout approximately 50 feet away. The clear clean out has a hose connection so you can rinse the tank. I carry it in the bumper of the trailer, I have never used it on the road. If you do a search on RV net several different designs are floating around for portable Macerator pump, some are even built into cases.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
09-29-2007, 07:10 PM
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha
, Wisconsin
Gen D,
I don't know if I have a problem getting the waste to flow since I've never "flowed" my waste... but while I'm at renovating my trailer I'd rather set things up to operate via the push of a button than to have to play around with a 3"x 8' long sh*t filled slinky.
09-29-2007, 07:44 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Originally Posted by wader
Gen D,
..... I'd rather set things up to operate via the push of a button than to have to play around with a 3"x 8' long sh*t filled slinky.
So is the idea to be able to get rid of the sewer hose for a garden hose?
09-29-2007, 08:31 PM
Yeah. I'd rather wrestle a garden hose than a slinky.
That was 100% of the motivation in my case. Well, 90% anyway. The other 10% was because the blacktank outlet was on the curb side rear, and my graywater tank outlet is streetside center. I routed the macerator line up to streetside center so both outlets are at the same place. Much more convenient.
The outlets are Teed together so I use the same hose for both, and the graywater pushes out the residual black stuff.
Finally, I like having the threaded connections on the garden hose, and not having to worry about a slinky hose slipping off it pins, or coming undone when the flow is greatest.
09-29-2007, 10:45 PM
Broadway
Brad, you might take a look at the Sewer Solution. If you have a water supply (e.g. campground, home, or dump station), the Sewer Solution is a fairly effective macerator and can pump a pretty good distance.
One big advantage is that it cleans itself up nicely and is easy to stow.
Sewer Solution
............Scott
2006 Safari SE FB
Broadway, NC
