Old 10-14-2021, 12:28 PM   #21
Jrg
Springdale , Arkansas
Our 23fb had a similar leak. Opened the small access plate and I could see the "spin fitting" that is connected to the water outlet was cracked. There are many post with this failure. Most folks say the only way to repair HDPE is with heat fusion. I did contact JB weld and they said if the crack was completely dry their Plastic weld "might" work. HDPE is so slick glue wont bond. I enlarged the small access with tin snips and used a heat source and some HDPE welding strips to seal the crack. After I did my best to heat fuse I coated the crack with the JB plastic. The leak has stopped for now. Good luck
Jrg is offline   Reply With Quote
Use Black Water Tank as Aux Fresh Water Tank? DaytonaDan Plumbing - Systems & Fixtures 20 10-26-2016 08:53 AM
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 05:21 PM
leaky leaky leaky Zellia All Argosy Trailers 8 08-07-2015 06:25 AM
Leaky fresh water tank scubadog 2009-2015 Flying Cloud 3 08-01-2013 06:31 PM
Leaky fresh water tank nellie the elephant Fresh Water Systems 3 10-13-2003 03:12 PM
