Old 11-22-2023, 06:50 AM   #1
2008 532 International
Peoria , Arizona
Leaks from Black/Gray Tank Piping
Hello Everyone.
Just returned from camping in our 28’ International this week and noticed 2 leaks. Both the black and gray tank are leaking from the end of the tank where the piping leads to the main dump valve attachment. My questions are:
1) Can I just remove the dump valving assembly and piping and repair where the pipes join the tanks? I’m assuming it can be as simple as re-sealing these joints.. but I just haven’t done it ever.
2) If I need to replace the entire dump assembly, where can I find that part? I’ve been unable to track down the correct part..
I’m assuming that road vibration has weakened the seals on this piping, but if anyone has any input I’d appreciate it!
And if anyone has done this, any advice for the process?
I’ve attached a few pics highlighting where the two leaks are. The third is the image of the main dump assembly that joins the black/gray tank.
ID:	438936   Click image for larger version
twointwoout is offline   Reply With Quote
Old 11-22-2023, 09:55 AM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
It looks like the leak is at a adapter at the tank neck. It also looks like the adapter is held in my a clamp. My guess is you need to loosen the clamp, pull the adapter out of the tank neck, clean everything, apply some sealant and reasssemble.
CRH is offline   Reply With Quote
Old 11-22-2023, 03:06 PM   #3
Mollysdad's Avatar
Is that a hose clamp? Is it securing a rubber adapter?
Those are used a lot to join different size pipes in homes, not all bad since it should provide some flex to the pipes. But I'd start there. Easily available at the big box stores.
The parts manual should show an exploded view of the drain system. I have no idea what the rusty adapter is.
ID:	438957   Click image for larger version
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
LEAKS LEAKS more LEAKS in ATL parzam21 General Repair Forum 17 12-27-2015 02:46 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
