Old 08-16-2020, 01:08 AM   #1
Leaking Fresh water tank
My 2011 27FB has sprung a small leak in the fresh water tank, right where a pipe fitting enters it. What’s the best way to seal the small pinhole?
letsgetaway is offline   Reply With Quote
Old 08-16-2020, 11:43 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The tank is made of HDPE, and there isn't very much that will stick to that. There have been a few threads that discuss the various glues/sealants that might stick, and I recall someone swearing by one. Search for terms like "plastic weld tank" or "repair tank" and your should find some good hits.
Since it looks like your spun-on fitting has cracked, the best way to fix it would probably to cut it off, and spin a new fitting on in its place. This would probably require removing the entire tank, though, so you may want to exhaust all possibilities with sealants and glues first.
good luck!
Help! Water Leaking into my Fresh Water Tank dasams Fresh Water Systems 15 06-21-2017 08:57 PM
Leaking fresh water tank Yorkrus Fresh Water Systems 5 08-19-2007 12:44 AM
Leaking Fresh Water Tank gaylejoe Fresh Water Systems 9 09-30-2006 07:04 PM
Anyone fixed a leaking fresh water tank? JohnGalt48 Fresh Water Systems 2 06-28-2004 01:59 PM
HELP fresh water tank leaking wvabeer Fresh Water Systems 2 04-08-2003 11:10 AM
