Old 09-27-2020, 03:43 PM   #1
2014 19' Flying Cloud
Selinsgrove , Pennsylvania
Leaking black water tank
We have a new problem on our 2014 19'Flying Cloud. This summer towards the end of a trip we had black water tank leakage at our site. (a slow drip). We thought that it was because we were almost full. Fast forward to this trip. Black water tank is nearly empty. We pulled into our campsite and opened the cap on the drainage valve and immediately had black water come out (2 cups worth). (valves are shut). What is going on? Is there a seal broken? Any help would be appreciated!
wmbechtel is offline   Reply With Quote
Old 09-27-2020, 04:52 PM   #2
2018 25' International
Slidell , Louisiana
Could be a bad seal or more likely some trash, perhaps toilet paper in the seal. Clean the tank well then Empty the tank, Then run a hose with a jet nozzle up the drain to flush the valve area. Do it just before or during a hard rain so any minor issues flush away or take it to a car wash and do it there. While flushing, cycle the valve several times. Then adjust the valve throw so it fully closes and fill the tank with fresh water and see if it leaks. If it does try again. No luck? the seal is damaged and may need to be replaced.
A good way to prevent TP from causing an issue is to dump the tank first thing in the morning before any use and then leave any additional morning contents plus a couple gallons of extra water for the next stop. The sloshing will break up the TP in just a few minutes.
Brian
1992 35' Excella black-water tank leaking Doug C Waste Systems, Tanks & Totes 7 06-28-2015 08:00 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Leaking Black Water Tank LWPittman Waste Systems, Tanks & Totes 2 01-21-2012 06:38 PM
Leaking Black Water Tank ssolid Waste Systems, Tanks & Totes 6 04-10-2009 07:26 PM
Black Water Tank Shut-off Leaking tntom Waste Systems, Tanks & Totes 2 07-03-2008 06:38 PM
