Solution to stubborn dirty grey tank sensor
Tried many of the remedies out there filled tanks with pinesol, dawn, tank buster, rv digest it, and even 20 gallons of vinegar, (for calcification) drove it on bumpy roads etc etc nothing worked. These solutions are good for maintaining a clean tank which we did not do for over a year., so something stubborn was stuck on the wall of the tank over the sensor
Bought camco tank hose spray (for black tanks) and inserted through the grey tank dump valve, this yielded a bunch of nasty grime which I had to bucket out, but the spay would not hit the sensor wall (probably) because of nozzle orientation. Almost gave up but then figured I try one last method.
Bought a hose sprayer nozzle and modified it as per attached pics for the spray to shoot outwards. Stuck the hose into grey tank pressure equalization valve/pipe and viola a bunch more grime came out and sensors are back to normal. I could not do this with the Camco hose attachment because it would not be fit into the pipe.
See attached pics
Hope this helps someone down the line.
