Old 06-05-2024, 04:40 PM   #1
2022 Caravel (sold)
2021 20' Caravel
2015 27' Flying Cloud
Paso Robles , California
Hooked hose to flush valve instead of city water
Not a newby but a newby mistake. Day 40 of a 48 day trip. Our 25th site so far. Got distracted connecting city water and attached it to flush line. Discovered my error when water was coming out of AC vent near the bathroom.
Internally how does water get from the Black Water tank to the AC vent? I had water on the roof as well. I assume the vent pipe is not exactly watertight and allowed water to get inside the shell and then appeared where it did. I do not want to remove the skin to replace the insulation and am fortunate we are in the desert for the next week. We also store in the desert so maybe the 90-110 degree heat and low humidity will help. Not worried about mold (I used to do mold inspections for a living) but I am worried about other things growing in the shell.
805Vet is offline   Reply With Quote
Old 06-05-2024, 07:09 PM   #2
MMCMRET's Avatar
2021 25' Flying Cloud
Fredericktown , Ohio
I just put new siphon 360 vents on my rig. Went I looked down both grey and black tank vent pipes it appeared to be a straight shot to the tanks. These systems are not connected.
This is a long shot....How close is the roof-black tank vent located to the roof air conditioner?
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
MMCMRET is offline   Reply With Quote
Old 06-05-2024, 08:05 PM   #3
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
On our trailer (2005 Classic) the black and grey vent pipes are connected together. There is only one vent pipe coming through the roof.
I suspect in your case, the amount of water got past the AC seal on the roof. Also, it sounds like you will be fine getting the moisture cooked out of any wall or ducting.
10Smiles is offline   Reply With Quote
Black water flush when no threaded flush hose? hikingcamera Waste Systems, Tanks & Totes 17 08-26-2022 06:18 PM
Water leak when hooked up to city water. Please help :) jck_dmb General Repair Forum 29 11-24-2020 09:17 PM
City Water Hooked Up Making Fresh Water Tank Leak/Overflow??? Wgbarrbevco Fresh Water Systems 18 11-24-2017 03:45 AM
water dripping from city water hose attachment location when NOT hooked up to city wa roscher Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
Hooked hose to flush valve instead of city water... Denis4x4 Waste Systems, Tanks & Totes 9 09-25-2007 09:50 AM
