05-27-2022, 12:42 AM
Tahoe Vista
Holding tank sensors with no readings at all
Hi all! After de-winterizing last weekend, my holding tank sensors have no readings at all. I am used to them misreading and giving faulty tank level info, but neither the black or gray water tanks read anything now.
Anyone have an idea of why I would be not getting any waste tank level readings? (Fresh water tank levels read properly)
Thanks!
JJ
05-27-2022, 05:54 AM
2020 25' Globetrotter
Hillsdale
, New York
Stupid question, but I am assuming you have plenty in the black and gray tanks?
SPP
05-27-2022, 07:55 AM
Houstatlantavegas
, Malebolgia
Welcome Aboard...👍
I learned to think about it like this...how long could I continue to work if I was covered in poop half my life?
I did the GeoMethod once years ago.
Now it's 1/8 cup Dawn and Happy Camper after every dump and through flush.
POI all our sensors are still working....
05-27-2022, 08:16 AM
2013 27' FB International
2012 23' Flying Cloud
GVA
, British Columbia
No Readings ? no power? = could be a fuse.
Laurence
05-27-2022, 08:20 AM
2006 19' Safari
Anaheim
The connector for the black tank sensor (at least on my 19) is located on the outside plumbing that feeds into the dump valve. This connector is subject to all matter of road debris and moisture. Mine rotted out after about 3 years and while I have a pretty good feel for how long we can get by, a quick check with peek down into the tank is a pretty reliable monitor.
Think like a Proton-Stay Positive!
05-27-2022, 08:22 AM
Tahoe Vista
Thanks all!
SPP, the black water tank was not very full, but the gray water tank was completely full and overflowing the shower just a bit.
Bob, I will give that geo method a try. I did use some cascade dish washer detergent in the full gray tank and drove around for about an hour but it did not have an effect.
I guess my concern is that there is no readings at all. I thought that if the sensors were covered with “stuff” they would still read out tank level info, just not accurately.
Sounds like you all are saying that no readings at all could also mean the sensors are clogged up?
05-27-2022, 08:28 AM
Tahoe Vista
Laurence and John, thanks! I am thinking it is more something like one of those issues as I am not getting any readings.
I didn’t even think about a fuse blown. Would that fuse just run the black and gray water tank power though, or would it also run other electronics as well? I don’t notice anything else electrical not working.
As for the sensor connector that is curious. Is there the same type of sensor for the gray tank as well? What are the chances both went at the same time? Definitely a possibility.
Thanks guys!
05-27-2022, 09:45 AM
2016 25' Flying Cloud
Friday Harbor
Me too
I am having no reading at all. Whole unit not lighting up. Anything to do with on and off switch on battery disconnect?
05-27-2022, 09:53 AM
2016 30' Classic
Houston
I use a mix of Dawn Ultra dish detergent and liquid Calvin water softener. I understand that the inclusion of the liquid Calvin is particularly important when hard water is in the tanks.
Friday Harbor
Me too and…
Nothing on inverter circuit coming on. Shore power OK.
05-27-2022, 11:29 AM
1971 31' Sovereign
palm bch. gardens
Sounds like nice to me!
05-27-2022, 11:42 AM
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake
Good Advise
Good Advise,
We found the dawn soapy dish water down the black tank does a great job between clean outs while traveling
05-27-2022, 06:38 PM
1988 32' Excella
Robbinsville
, New Jersey
Thanks guys!
When at the same time means "during months of winter storage" the odds of both at the same time increases.
I believe Peggy Raffer meant MICE chewing wires which is another possibility.
05-27-2022, 07:36 PM
2002 19' Bambi
Lafayette
It would be useful to know the age of your trailer because that can have a lot to do with no readings.
Our 2002 came with simple electrical contacts. Airstream then changed to the Micropulse system and then to the SeeLevel system. Of the three, the SeeLevel system is, by far, the most accurate and reliable. The reason is that the sensors are on the outside of the tank and (unless solids are stuck to the side of the tank with the sensor) problems with the system would most likely be wiring- or fuse-related.
Tim
05-27-2022, 10:39 PM
Tahoe Vista
Tim
Thanks Tim! It is a 2009 25’ Flying Cloud. I am not sure what kind of sensor system it has. I will check out the owners manual to see if it is in there. Do you happen to know what type of senses airstream was using in 2009?
05-28-2022, 05:28 AM
Charlotte
, North Carolina
Same. We used the Dawn & Happy Camper and had fully functioning sensors on our previous SOB for 3 years. I'd stay away from adding bleach as that can have a negative effect on your tank and valve seals.
In this instance, however, it sounds more like a sensor issue.
'23 GT 27FBQ (on order)
'18 F350 Lariat Ultimate, 6.7 PSD
