Grey water tank
Just finished replacing both dump valves, 3" pipes, adapters and new level indicators. Filled balck water tank to 2/3rds full and all is tight. Filled grey water tank and all is tight, EXCEPT, I had water pouring out from under door side. Found two inches water in shower pan.
I have unit jacked up pretty steep on side to get to dump valves and should only have filled to half full to test.
Question is: Is there an overflow on top of the grey water tank?? Most of the water was coming out pan corner opposite dump valve area.
