Old 03-05-2021, 01:58 PM   #1
1999 28' Excella
Rowlett , Texas
Send a message via Yahoo to Techfan70
Grey water overflow on ‘99 28 ft Classic
I was checking for leaks after the temp dropped to 1 degree and the power was shut off. So after warm up I closed the grey water shut off and filled the tank from the shower till it was full and I saw water pouring out of bottom of trailer. It seamed to stop after the water level went down. Does the grey water tank have an overflow or do I have a leak? Doesn’t seem to leak if I don’t fill the tank full.
Thanks for any input!
Richard P. Johnson
Techfan70 is offline   Reply With Quote
Old 03-05-2021, 02:41 PM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Did you put pink stuff in shower drain?
Possibly a frozen trap cracked.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-05-2021, 07:39 PM   #3
1999 28' Excella
Rowlett , Texas
Leak
Thanks, can you tell me about the pink stuff?
Old 03-06-2021, 07:15 AM   #4
GCinSC2's Avatar
RV antifreeze.
Many threads on winterizing but I pour a couple oz in each sink to prevent the sink or shower trap from freezing.
S/OS #001
Old 03-06-2021, 11:29 AM   #5
2021 16' Caravel
Long Beach , Indiana
RV antifreeze.
Just curious....do you pour in "the pink stuff" every time you use the sink or shower while you're camping in below freezing temps?
Yvonne
Whyvon2509 is offline   Reply With Quote
Old 03-06-2021, 11:47 AM   #6
Dan and Lynda
2012 28' International
Bremerton , Washington
I'm here is Washington State. I put the pink stuff down each drain each winter. To protect the drain valves outside, I put about a gallon down each drain to make sure that any residual water in the grey and black tanks gets enough antifreeze to protect the drain valves and pipes outside. If I'm camping I do not use any since the tanks are heated by the furnace ducts so it keeps it warm. In general I do not camp below 20 degrees often.
The Cralls is offline   Reply With Quote
Old 03-06-2021, 12:12 PM   #7
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
The pink stuff is an antifreeze. It’s a once per winter process to prevent pipes from freezing.
You seem to be asking if you have a problem caused by freezing. You might. If so, it’s too late for the pink stuff this winter.
There are not overflows in the black or grey systems unless you or a prior owner modified the plumbing system. Having those would lead to waste water spills on the ground. Overfilled systems back up to the lowest visible point. Typically, an over full grey system would appear as standing water in the shower pan. A black system would be a toilet that wouldn’t flush.
Your symptoms and description suggest that the grey tank was empty when the freeze hit? Were you camping, or was the trailer in storage? Was the furnace running to keep the living space warm? GC2 is suggesting that the shower drain trap may have had plain water in it, froze, cracked the trap and now is leaking. That sounds like a good guess to me.
If the trailer was unheated and unwinterized, there could be other leaks in other traps or even supply lines.
Silver Cliche’
Follow us at...
silvercliche.blogspot.com
GammaDog is offline   Reply With Quote
Old 03-06-2021, 12:18 PM   #8
GCinSC2's Avatar
We have not camped in sub freezing temps.
But that is where using the gas furnace and it has a hose that blows hot air below the floor at the tanks. That area on my rig is below the shower trap and warm air from that hose should prevent freezing. My understanding. The kitchen and lav traps are in the heated area and should not be a problem.
Storage in sub freezing, pink stuff in traps and winterized is my approach.
But SC gets a fairly easy winter in my area.
Gary
S/OS #001
Old 03-06-2021, 07:22 PM   #9
1999 28' Excella
Rowlett , Texas
Thanks, the grey tank was emptied before a cold snap occurred. I left the heater on during the cold weather but our electric leaders cut the power on several million customers, my power could have been out for some time. I plan on using a sewer hookup at RV parks until I can get it fixed so the grey water should not accumulate to the leaking point.
Richard P. Johnson
Old 03-07-2021, 05:48 AM   #10
GCinSC2's Avatar
Richard,
Empty tank shouldn't freeze up.
Gary
S/OS #001
Overflow from gray water to black water tank? Msmoto Waste Systems, Tanks & Totes 24 12-14-2020 08:25 PM
City Water Hooked Up Making Fresh Water Tank Leak/Overflow??? Wgbarrbevco Fresh Water Systems 18 11-24-2017 03:45 AM
Water dripping from fresh water overflow? craftsman Fresh Water Systems 10 10-09-2010 10:58 AM
City water overflow Dieselgrin Fresh Water Systems 1 11-14-2008 04:46 AM
Filling fresh water tank- overflow normal? John Fresh Water Systems 20 02-23-2003 12:43 PM
