04-07-2011, 03:58 PM
1967 22' Safari
1978 25' Tradewind
NEW LENOX
Grey Tank choice - ABS or Polyethylene?
So I am making progress on the design for adding grey tank capacity to my 78 Tradewind. The choice is between vacuum formed ABS tanks or roto molded Polyethylene tanks. Is there a reason to buy one versus the other?
Here's how I see it:
ABS - almost twice the price (~$200+ each)
- I can easily drill out and glue on the fittings
Polyethylene - almost half the price of ABS (~$100+ each)
- Need the vendor to spin-weld the fittings in place (or use the rubber fittings)
And, assuming I properly support the either tank, is one more durable than the other?
Thanks, John H
04-07-2011, 04:34 PM
OO
, OO
In my Cruiser I want no plastic tanks, everybody 4 is built from chrome steel....
Werner
04-07-2011, 05:05 PM
1974 31' Excella 500
Charleston
, South Carolina
Werner ain't play'n.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
04-07-2011, 05:08 PM
1967 24' Tradewind
Greenville
, South Carolina
I went ABS because I was not confident that I could get the inlet exactly where it needed to be and can easily add myself.
04-07-2011, 06:21 PM
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
I've got Poly for my gray tank and ABS for my black tank - only because I found 2 different tank sizes to fit in the 2 different existing spaces. I don't know what the advantages or disadvantages are for either. However, I do know that my poly tank "feels" more substantial than the ABS tank.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
04-07-2011, 06:59 PM
1976 25' Caravanner
Campton
, New Hampshire
ABS is easier to repair if that is a consideration .
04-07-2011, 07:12 PM
1954 25' Cruiser
Cruisin
, Wisconsin
Thanks, John H
I have not installed yet but I got my abs tanks here: RV Surplus
So I could install the fittings where I wanted. I thought the prices were good there to, the shipping hurts a little though.
04-08-2011, 09:48 AM
1967 22' Safari
1978 25' Tradewind
NEW LENOX
Tinman, thanks for the RVS link. You're right, their prices are good.
The RVS ABS prices are close enough to the poly prices so I'll go with ABS.
Thanks for the help everybody.
John H
04-08-2011, 10:39 AM
1997 30' Limited
Omaha
, Nebraska
I've had good luck with this Canadian Company. I purchased their AC shroud with a lifetime warranty. I talked personally with someone there and found them very helpful.
RV waste holding tanks
I'm not sure how their prices compare.
JIM
Rig: '97 30' Limited
Towed by: '19 Silverado 2500 Duramax
WBCCI #22116
04-08-2011, 11:19 AM
1967 22' Safari
1978 25' Tradewind
NEW LENOX
I just quick checked a couple of prices. They are ABS and are typically twice the price or more, of RV Surplus. But they do say 2 days turnaround. RV Surplus is three week turnaround.
John H
04-08-2011, 05:08 PM
1954 25' Cruiser
Cruisin
, Wisconsin
John H
John
It did take all of 4 weeks to get my tanks from rv surplus. I got really tired of looking for tanks.
Doug
04-08-2011, 05:25 PM
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge
I only use stainless steal tanks!
Todd
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
04-11-2011, 12:12 AM
Tool Hoarder
West
04-11-2011, 02:05 AM
OO
, OO
Thank you Todd, I am of the same opinion! DanielB meant about it: "Werner ain't play'n", however I cannot translate this in German.....
04-11-2011, 05:41 AM
Always learning
1972 29' Ambassador
Central
Originally Posted by marzboy
I'm using the same tank from Ronco. I have two gray and one black tank. The total was around $500 to my door.
http://www.airforums.com/forums/f36/...tml#post947725
Lance
04-11-2011, 08:15 AM
Edge and corner thickness is kind of critical because this is often where they receive mechanical stress. ABS vacuum molded tanks are thinner at corners and edges because they are drawn over a mold while being heated. Roto-molded tanks are actually thicker at corners and edges because they are literally rotated in a mold.
04-14-2011, 03:19 PM
1967 22' Safari
1978 25' Tradewind
NEW LENOX
I am having a difficult time with this ABS versus Polyethylene tank choice. Today I am really thinking to go with poly... However, I really want to use the rubber fittings rather than order the tanks with fittings spin-welded.
You are supposed to use a butyl caulk with the rubber fitting.
Anybody have problems with the rubber fittings leaking?
In my design I will have a 5" deep tank and a 6" deep tank. When the 6" deep tank is full the water height will be above the 5" deep tank. In other words I will 'over-fill' the 5" tank which will put the rubber fitting 'under water' by a 1" water column, 2" if water backs up into the shower pan. The tank guys say 'no problemo' but I don't know.
Anybody had a bad experience with the rubber fittings?
Thanks, John H
04-14-2011, 05:40 PM
1960 24' Tradewind
Folsom
So is there a sealant we can use with the poly . . . And/or will the butyl caulk be "water tight"?
And a separate question (for Jammer):
Those fittings look great but how do you get the piece that goes inside the tank . . . in the tank (w/out drilling a larger hole somewhere else (sounds like a "dumb question")?
Seems like it would only work for small connections - where you could install the inside piece through the large drain hole.
04-20-2012, 01:58 PM
Sunset Beach
, North Carolina
How will the weather affect these tanks?
My factory poly black tank is in an enclosure with insulation and a heat source. From the pictures I have seen, the ABS will be exposed on the bottom. Is there a freeze risk?
I am about to order a black and a gray, not sure which way to go....as usual.
