Old 12-24-2021, 07:55 AM   #1
Barracuda's Avatar
1996 30' Excella
Jordan Falls , NS
Grey & Black Water Sensors
Does anyone know where the grey and black water level sensors are fitted on a 1995 Excella 1000 (31' model).
Also does anyone know what type of sensor they are, and can you still buy or if not buy an equivalent.
Thanks.
Barracuda is offline   Reply With Quote
Old 12-24-2021, 09:30 AM   #2
Rich W's Avatar
I'm In , Kentucky
On my 2006 23' I have a Micropulse. The black tank sensor (currently not working) is located on the dump pipe just above the pull valve. There is an RJ-11 telephone style wire connected to it.
The gray tank sensor is working (more or less) and I haven't scouted that out yet but I found a post that says it's on the gray dump pipe like the black tank sensor, just above the pull valve.
The fresh water tank sensor in mine isn't working. I'm told that it is above the belly pan and would require a hole to be cut to access it. Since we rarely use the FW tank (we do sanitize it, however) I haven't worried about getting it replaced. A few years ago the sensor was $55 but I see now it's $75.
https://shop.catconproducts.com/cate...c?categoryId=2
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 12-24-2021, 12:53 PM   #3
2002 19' Bambi
Lafayette , California
Our 2002 came new with electrical contact sensors. The Micropulse system was used later in Airstreams. We "upgraded" to Micropulse and, when that turned out to be a poor solution, installed a SeeLevel system. The latter is far superior to our former two systems.
I suspect that your 1995 had the same electrical contact sensors we had in our 2002. I never checked to see, but I suspect that they just measured resistance which would be lower with fluid in the tank. Ours were inserted at about 3 levels through the walls of the tanks.
Tim
Tim A. is offline   Reply With Quote
Old 12-25-2021, 07:57 AM   #4
Barracuda's Avatar
1996 30' Excella
Jordan Falls , NS
Thanks everyone, I will check when the weather is better. Merry Christmas & a Happy New Year
A bit weird - SEELEVEL II tanks sensors Fresh Grey Black LPG Alex AVI Sprinter and B-van Forum 5 05-23-2018 07:37 PM
2014 19’ Bambi - Grey & Black water sensors Rollin4eyes 2005 and newer - Bambi all models 9 03-25-2018 10:07 AM
What gauge wire to run to new Horst grey tank sensors? chilipepper Plumbing - Systems & Fixtures 0 06-24-2014 11:36 AM
Replacing black/grey with a larger grey whitney Waste Systems, Tanks & Totes 11 05-08-2012 07:47 PM
62 tradewind black water & grey water option Trophycare Waste Systems, Tanks & Totes 0 06-30-2010 10:05 PM
