Old 06-21-2018, 03:15 PM   #1
1965 22' Safari
Coalmont , Colorado
gray water tank fixtures
Hi,
I'm toward the end of refurbing '65 22" Safari. Putting in a composting toilet so I can add gray water tank. When I bought the tank, I didn't have the entry and exit issues planned so no holes in tank. Can I just use ABS glue or epoxy or what is best to avoid possibility of leaks? Tks, Notyetshiny.
Notyetshiny is offline   Reply With Quote
Old 06-21-2018, 06:40 PM   #2
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
The fittings for the tank itself either get spinwelded in or the hole is cut & then a rubber gasket is used between the tank & the fitting.
I'm not sure about gluing them directly to the tank.
I'm nearing the end of my refurbishment too. :-)
Dingo Girl is offline   Reply With Quote
Old 06-21-2018, 08:23 PM   #3
1949 18' Trailwind
Salt Lake City , Utah
It depends on the type of tank
You can buy some grommets like this one if your tank will work with them. Use the grommet to mark your floor and drill through the subfloor with the appropriately-sized hole hog. Then just drill the hole through the top of the tank and press the grommet in. You'll have to google (or call Icondirect who makes them) to see what adhesive to use. The vertical pipe just fits inside the riser on the grommet and gets tightened with a hose clamp.
https://www.rvautoparts.com/12484-Ic...BoCg34QAvD_BwE
KellySLC49 is offline   Reply With Quote
Old 06-21-2018, 09:50 PM   #4
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Spin welding is usually the best way to go. The supplies are a bit spendy. Bulkhead fittings can be done, but you have to find a way to get the nut on the inside of the fitting and tighten it down ... can be tricky.
I suggest contacting the vendor you got the tanks from and getting their recommendations.
TheGreatleys is offline   Reply With Quote
?s on outfitting outlet/inlet/vent fixtures on gray tank... PA BAMBI II Waste Systems, Tanks & Totes 0 03-30-2017 01:48 PM
Covert fresh water tank to a gray tank cole3444 Waste Systems, Tanks & Totes 3 03-25-2014 06:31 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
