Old 03-13-2022, 07:49 PM   #1
2022 28' Pottery Barn
Las Vegas , Nevada
Gray water read at 40%, even though itís empty
Hello friends,
This is probably a common issue. So my gray water tank is completely empty, but it still reads ~40%, any recommendations for making it reads correctly? Thx!
Btw, my trailer is only 4 months old.
davydliu is offline   Reply With Quote
Old 06-04-2022, 09:06 AM   #2
Hansanabi's Avatar
2019 25' International
Huntsville , Alabama
my grey tank sensor says 69%
davydliu,
This is a common problem. You can search YouTube for solutions. The problem seems to be not with the sensor itself, but with dried-up gunk built up on the inside of the tank wall. Bottom line, the inside of the tank needs to be cleaner (easier said than done)
2019 Airstream International Serenity 25FB, dual A/C, 50Amp
Hansanabi is offline   Reply With Quote
Old 06-04-2022, 09:11 AM   #3
2017 28' International
Jim Falls , Wisconsin
I just had the same problem. Stuck at 69%. But after using it and driving it the reading corrected itself. My guess is as above, there was something on the sensors.
Daquenzer is offline   Reply With Quote
Sea Level II - Fresh water tank stuck on 100%, even when empty Troutboy Fresh Water Systems 12 01-31-2021 12:40 PM
shower drain always flooding even with empty tank dedalus Plumbing - Systems & Fixtures 26 10-10-2020 08:24 PM
Noisy water pump I've decided even though it isn't broken I'm gonna fix it jimin pa Fresh Water Systems 52 08-30-2016 05:36 AM
Gages read empty always superman LP Gas, Piping, Tanks & Regulators 4 05-20-2013 09:32 AM
Battery at 45% even though connected to shore power SilverGate Batteries, Univolts, Converters & Inverters 27 04-17-2009 04:35 PM
