Old 10-17-2021, 02:32 PM   #1
TorpedoFamily
Torpedo Family's Avatar
2014 30' Classic
Ozark , Alabama
Gray water dump extender pulled out
When I pulled my gray valve to dump today it cam out. Looks like the bolt that holds the extension to the valve broke. Will I have to cut the belly pan to get to the valve to put in a new bolt? It is a 2014 Classic 30 foot. The valve has been hard to open and close for a while. The black valve is same. It is like it needs lubrication. I am on the road for another week. Gray valve is open.
Torpedo Family is offline   Reply With Quote
Old 10-17-2021, 03:47 PM   #2
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Here's how to stop that from happening again.
https://youtu.be/TGv9THpOdmw
kscherzi is offline   Reply With Quote
Old 10-17-2021, 04:21 PM   #3
TorpedoFamily
2014 30' Classic
Ozark , Alabama
Dump valve access
Thanks but I can not see my valves they are behind the belly pan.
Old 10-17-2021, 05:10 PM   #4
kscherzi's Avatar
Images: 24
Mine too but the black valve was reachable, just barely, with the cordless drill. Its just behind the belly pan if you look through the slot where the pull handle shaft goes.
Old 10-17-2021, 05:40 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
If ai recall correctly, my valve extensions were secured to the valve with a pop rivet. I do know that is how I put the old extensions on my new dump valves...I had to cut a access hole to do the work. I cut the holes then made a cover plate from an old street sign.
CRH is offline   Reply With Quote
Old 10-18-2021, 06:42 AM   #6
TorpedoFamily
2014 30' Classic
Ozark , Alabama
Thanks, that is what I am feeling about cutting out an access hole. And yes the pop rivet broke. I did not know how the extension was attached.
Old 10-18-2021, 01:06 PM   #7
2019 25' International
Washington , Washington, D.C.
Note to all: use a lubricant like 303 Aerospace Protectant (that you might already use on your window seals) on the sliding parts of grey/black tank valves. The valves slide out and in much more smoothly after lubricating.
PatLee is offline   Reply With Quote
Old 10-18-2021, 01:28 PM   #8
2015 27' FB International
Erie , Colorado
Dump Valve Pull Handle
My black dump valve handle did the same thing a few weeks ago. i was able to pull out the valve with a pair of vice grips and found a short bolt the right size to reattach the extension handle. I double nutted the bolt and added some red locktite on the nuts.
Rockhound100 is offline   Reply With Quote
Old 10-19-2021, 07:48 AM   #9
TorpedoFamily
2014 30' Classic
Ozark , Alabama
Dump valve extension pulled out
I thank everyone for your advice, I hope I can get to the valve where the extension connects to replace the bolt without cutting out the belly pan. Will post after I have repaired it with my procedures.
Old 10-19-2021, 09:25 AM   #10
2018 26' Flying Cloud
WARNER ROBINS , GA
valve lubrication
Hello all,
When my gray tank valve got difficult to open I finally reached someone who actually had a solution.
Empty the gray tank completely, close valve, pour about 16 ounces of coconut oil into shower drain and let it drain into tank. Let it sit there about 15 minutes to give it a chance to collect at the valve gate. Go out to the valve and open and shut it rapidly a whole bunch of times. This will lubricate the blade and rubber seals. I have done this two or three times on my 2018 and all is well. The person I spoke with said the soaps from the shower and sink dry out the seals and make it hard to slide. The coconut oil is a safe lubricant. No worries about it being in the tank as normal use the soap will wash it all out.
Happy Camping
jrwayne is offline   Reply With Quote
Old 10-19-2021, 09:39 AM   #11
CRH
1995 25' Excella
xxxxx , xxxxxx
I would think that only 16 ounces would at best just reach the very bottom of the seal.
Old 10-23-2021, 08:25 PM   #12
lemley's Avatar
1988 29' Excella
Lorena , Texas
valve lubrication
Originally Posted by jrwayne View Post
Hello all,
Happy Camping
My rig is an '88. Officially "vintage" for 8 years.
When my gray valve started getting hard to operate and I started getting worried someone on a podcast suggested "Thetford RV Drain Valve Lubricant". It worked immediately and I've used it regularly on the gray tank ever since.
The podcast happened to be by one of the guys that developed "Valterra Pure Power Blue". Along with being all natural and acting as a waste digester and odor eliminator, Pure Power Blue also lubricates the black tank valve.
I use both regularly.
lemley is offline   Reply With Quote
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 23 11-04-2022 07:48 PM
Help! Tire blow out and ripped out gray water valve pull rod marcesq General Repair Forum 13 06-24-2018 10:46 AM
Gray water dump valve in bambi... Sro Plumbing - Systems & Fixtures 2 02-07-2015 07:06 AM
Help I pulled the wires out of my 7pin conection to tow vehicle. AustinAir Towing, Tow Vehicles & Hitches 9 01-10-2009 06:24 PM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 12:13 PM
