Old 05-14-2018, 05:06 AM   #1
AFTER TAXES's Avatar
1964 22' Safari
1993 25' Excella
Flagler Beach , Florida
gray water
is adding bleach to the gray water tank a good idea ?
smells like rotten eggs !
AFTER TAXES is offline   Reply With Quote
Old 05-14-2018, 05:22 AM   #2
Lily&Me's Avatar
Normal , Illinois
There are lots of threads here on sanitizing your tanks, if you use the blue search box at the top of the page.
Some add a small mount of bleach to each tank, others sanitize just at the beginning of each season....and there are all manner of habits in between.
Maggie
Old 05-14-2018, 05:38 AM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
I use some of the same enzyme treatment that I add to the black tank.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 05-14-2018, 06:54 AM   #4
2018 28' International
Fayetteville , Georgia
I add the orange tank treatment, same as I do for the black water tank. You might also consider flushing the grey tank.
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 05-14-2018, 07:32 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Like it or not, waste water can "grow stuff" in it. The idea of the enzyme tablets is to encourage less stinky processes to occur. If your gray water system is smelling, the first thing to do is a really good flush. It may take a couple of fill and dump cycles to get things under control. Bleach may help, just don't go crazy with it. The same is true of normal pipe cleaning solutions. A little is ok, dumping 5 gallons in .... probably not a good idea.
Once things are a bit more tolerable water management is worth thinking about. Water / crud sitting in the tank for a long time is bad. Even if the tank isn't full, dumping on a regular basis is a good idea. How often is regular? I would not stretch it past twice a month. A good flush when dumping is part of the process.
With gray water, consider what goes down the drain in the kitchen. If you *can* put it in the trash, do so. The less organic matter goes into the tank, the less stink. Yes, this makes cleaning that grubby pot a bit more labor / paper towel intensive .... sorry about that
Lots of fun !!
Old 05-14-2018, 10:53 AM   #6
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
As bob said:
"With gray water, consider what goes down the drain in the kitchen. If you *can* put it in the trash, do so. The less organic matter goes into the tank, the less stink. Yes, this makes cleaning that grubby pot a bit more labor / paper towel intensive .... sorry about that "
Our dishes are "almost" clean when we wash/sanitize them.
I also drop the same tablet we use in the black tank in the shower drain, followed by about two gal. water, if we are off the road for a month or more (which doesn't happen often <grin>).
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | ACI 1927 - Spirit of Virginia Club | AIR 53869
Silver Otter is offline   Reply With Quote
Old 05-14-2018, 07:15 PM   #7
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
I "cleaned" my tanks today, I poured about 1/2 gallon of bleach and a couple squirts of Dawn into both black and grey tank then put about 10 gallon water in each. After letting the solution soak on the bottom of the tank I drove the trailer around some back country roads while making several quick stops to get some washing action in the tanks. When I dumped the tanks I watched to see what the water looked like. The black tank was clear and clean while the grey water was cloudy.
Gary
Castaway is offline   Reply With Quote
Old 05-14-2018, 08:22 PM   #8
CRH
1995 25' Excella
xxxxx , xxxxxx
1/2 gallon of bleach in ten gallons of water sounds pretty potent.
CRH is offline   Reply With Quote
Old 05-14-2018, 08:41 PM   #9
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Serious question. Call me crazy. Why is it a problem that the gray water smells bad?
TheGreatleys is offline   Reply With Quote
Old 05-14-2018, 10:32 PM   #10
aftermath's Avatar
Spokane , Washington
I just use the same chemicals I use for my black tank. I only sanitize my fresh water tank. Don't see the point in doing the others. Rinse them, yes. Treat them, yes. Haven't sanitized them yet.
aftermath is offline   Reply With Quote
Old 05-14-2018, 11:20 PM   #11
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Great question.
Hi, and the answer is: We camped in a friends driveway and our friend and her neighbor said it was alright to drain our gray tank on the grass. Well is smelled pretty bad. Other than this type situation, you would never smell it. I found, and now use, a tablet made for de-odorizing gray tanks and it works great.
Name:	gray tank sanitizer.jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-15-2018, 05:43 AM   #12
Castaway's Avatar
Celina , Ohio
Typo 1/4 gallon
Gary
Dish Water, Shower Water, Gray Water... nvestysly Boondocking 63 10-26-2016 01:21 PM
Black Water/Gray Water TimeOut Plumbing - Systems & Fixtures 13 10-18-2015 07:00 AM
Shower water and the Gray Water Tank MIKO92 All Argosy Trailers 16 07-22-2014 12:53 AM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
