Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-04-2021, 12:10 PM   #1
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
Glue on Thetford to Valterra connection?
Hello everyone!
Quick question, my AS is an '88 so it has the thetford connection at the dump connection. I'm using a thetford to Valterra adapter much like this https://www.etrailer.com/RV-Sewer-Ho...nt=30%20-%2060.
Unfortunately the adapter is a little fiddly and leaks, I'm looking at cutting off the thetford connection and gluing on a valterra connection. I've read that's what others have done. Is this the right piece? https://www.etrailer.com/RV-Sewer-Ho...466V293B3.html
Thanks!!!
88Limited is offline   Reply With Quote
Old 12-04-2021, 12:31 PM   #2
1986 31' Sovereign
Miami , Florida
That will do it.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 12-04-2021, 01:15 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Looks like the correct part. I did it on my 1988 trailer. I am happy with it.
Old 12-04-2021, 01:24 PM   #4
Antsville , FUBAR
Originally Posted by 88Limited View Post
Hello everyone!
Thanks!!!
Like this?
I used 3m 4200
Old 12-04-2021, 01:43 PM   #5
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
Originally Posted by ROBERT CROSS View Post
Like this?
I used 3m 4200
Bob,
Yes, that's the adapter I have, but it leaks... My tank valves don't leak (for the time being) so I'm looking for a solid solution until my valves fail and I have to replace them, at that point I'll run new PVC with a valterra connection.
Old 12-04-2021, 01:44 PM   #6
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
Originally Posted by n2916s View Post
That will do it.
That's what I was hoping for! Thanks!
Do you know if the pipe coming out of the AS ABS or PVC? The new fitting I linked is ABS, I'll probably pick up some primer and universal glue.
Old 12-04-2021, 01:45 PM   #7
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
Bill,
Awesome, thank you. Do you know if the pipe coming out of the trailer is ABS or PVC? Looking for the right type of glue.
Old 12-04-2021, 01:58 PM   #8
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
All parts are ordered. Thanks everyone!
Old 12-04-2021, 03:33 PM   #9
1976 31' Sovereign
Oswego , Illinois
Do like lots of others have done cut thetford off glue on valterra, no more hassles, leaks etc. also if pumping serv. at rallies or boon dock type campgrounds most pumpers will not have thetford connections, sure cured lots of prob. for me when I changed.
Old 12-04-2021, 03:39 PM   #10
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
Featherbedder,
That's what I plan on doing! I hadn't thought of pump services, good info!
Thanks!
Old 12-04-2021, 06:55 PM   #11
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I suspect the 3" drain pipe is ABS. There is no need for high pressure PVC in this application.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 12-05-2021, 10:01 AM   #12
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
David
David,
Agreed and thanks for the input/looking.
The adapter I linked (and purchased) is ABS. I wanted something with a large/longer flange to go over the original 3" ABS pipe for strength (more surface area).
I'll update the thread with install info...
Old 12-05-2021, 03:32 PM   #13
1988 32' Excella
Robbinsville , New Jersey
With a 88 no guarantee it's still original, easy to tell BLACK=ABS, WHITE=PVC.
I added a third valve when I changed mine, nice insurance when one starts leaking.
Old 12-05-2021, 03:41 PM   #14
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
Wazbro,
It's black, so I'm going into this assuming it's ABS.
Patrick
Old 12-06-2021, 07:44 AM   #15
Antsville , FUBAR
MarineTex if you it really want a permanent fix.
I keep some in the AS tool kit.
This leak was repaired with MT in 2007.
The fitting was cross threaded and broke at 3am, that's when I started turning off the pump at night or when no-ones around.
ID:	408839   Click image for larger version
Old 12-08-2021, 10:16 AM   #16
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
Oof, that's some strong stuff there. The oatey glue for abs will work fine since the pipe is not pressurized. Plus with the weather we're currently experience in Georgia I can't maintain the 55 degree minimum requirement MarineTex has...
I also keep a bunch of pex fittings on hand!
Edit: I now see you repaired that threaded fitting with the MT. That's some bravery right there and proof of the strength of the MT. I would have replaced the fitting!
Glue or not to glue carver 1 Floor Finishes 15 06-15-2015 07:12 AM
Replace Thetford with Thetford or Valterra? evansm1974 Waste Systems, Tanks & Totes 1 10-06-2014 10:01 PM
Valterra to Thetford connection Craig Waste Systems, Tanks & Totes 30 03-05-2011 08:49 PM
Thetford vs Valterra pilgrim_still Waste Systems, Tanks & Totes 8 06-11-2005 02:34 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
