Old 11-29-2024, 09:01 PM   #1
lake buena vista , Florida
fun times. replacing grey and black waste valves in 2022 Caravel
It looks like this is the factory part:
https://www.etrailer.com/RV-Waste-Va...lated-products
I haven't disassembled the faulty unit yet, but will the new one just bolt or slip into place or, as I expect, will I need to cut out the factory unit and use ABS primer and glue along with slip joints to get the new one installed? Advice welcome. thanks.
bowling is offline   Reply With Quote
Old 11-30-2024, 06:19 PM   #2
nothing at all? this place used to be hopping with advice.
Old 11-30-2024, 06:37 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
May not apply, but.....
My 2002 had the valves screwed into the tank flange, but everything else was glued. I pulled the assembly and duplicated it with new ABS and PVC parts. If available you might consider rebuild kits for your valves.
2013 Ram 2500 Laramie 4x4 Megacab Cummins
Old 11-30-2024, 06:43 PM   #4
1988 32' Excella
Robbinsville , New Jersey
My trailer has a setup that is quite a bit different (many pieces glue together) so any advice might be off. The parts on the ends were into the tanks and held with hose clamps, if that is the correct part you linked you might need to disassemble the valves to get them into the tanks. Seems strange that the valves need to be replaced so soon, mine were original and about 30 years old when I replaced them.
Old 12-02-2024, 08:03 AM   #5
1972 27' Overlander
Lamar , Missouri
I am doing the same but plan on using flexible coupling with the unibody valterra valve.
walleye001 is offline   Reply With Quote
Old 12-02-2024, 08:51 AM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 196
RE: Waste Valves on Vintage Airstreams
Greetings walleye001!
My suggestion would be to strongly consider going with the Thetford components that would have been original on your trailer. My experience has been that the Valtera components while less expensive than similar Thetford components, they last 1/5 as long as a Thetford component. My 1964 Airstream has Thetford components while my 1978 Minuet was converted to Valtera by its original Owner.
I have owned my Overlander since 1995, and have only had to replace its Thetford gate valve once, and that was because it and the tank were damaged when I managed to get the rig high-centered on a rough county road entering a driveway damaging both the tank and valve requiring that I replace both. Otherwise, all the expense that I have had has been for two rebuilds over the years. On the other hand with my 1978 Minuet that was converted to Valtera components, I am constantly buying replacement parts as even the hose conectors fracture/break and seem to last no more than two seasons, and it seems that the gate valve isn't worth rebuilding as it has to be done every third season on average or at least that has been my experience on my Minuet. One of these days, my Minuet will be treated to new Thetford components.
Good luck with your project!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC/Pride Streamers/Wisconsin-UP Unit (Primary)/Missouri Greater Ozark Unit (Affiliate Member) #7864
AIR #827
1964 Overlander International
Old 12-04-2024, 04:37 PM   #7
2012 20' Flying Cloud
Los Osos , California
I replace the pipes and elbows from the tanks to the valves as well. It wasn't that hard. Do not try and clean the sender for the black water with anything sharp! It is a diaphragm and if you puncture it, you'll have to replace it.
Reay is offline   Reply With Quote
Old 12-05-2024, 09:39 AM   #8
Superannuated Member
Aironius's Avatar
2001 19' Bambi
Beaver Lake , Arkansas
Photos would help. My waste valves (2001 Bambi 19) were installed with bolt flanges and I just had to unbolt them and pry a bit of clearance to slide the old ones out and the new ones in.
Aironius is offline   Reply With Quote
Old 12-05-2024, 11:05 AM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
"nothing at all? this place used to be hopping with advice."
Yeah. I used to chime in on all the waste valve questions. But...your trailer is too new for me to comment on. My knowledge is really dated. Not many valve replacements on a 2 year old trailer, I expect. And...my source of supple of parts just quit selling parts too. I did change a valve back in September.
Old 12-05-2024, 11:43 AM   #10
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
So, what happened?
Maybe I missed something, but why are you replacing these valves anyway on a 2022 TT? I have owned 4 different year/model AS's over the years, and never had this issue...is this something that is "common" to watch out for? I do spray the handles often with silicon spray, but no issues in last 20 years. Curious as to why folks replace, unless damaged or leaking somehow?
2017 28' Twin Flying Cloud
Old 12-05-2024, 08:20 PM   #11
why replace?
I wound up not replacing anything but just removed, cleaned, and then re-installed the black valve assembly due to a fairly substantial leak. Why it loosened up, I don't know, but I have had to tighten up virtually everything from one end to the other of this trailer, so I'm not surprised to be honest. thanks for the advice. It is a pisser (no pun intended) to get the o-rings back in place due to the super-tight fit, and I'd be bet that I have a small pinch as the valve handle doesn't fit flush anymore, but for now, this will do. If I get motivated, I'll cut the black pipe and use a slip fitting for easier re-assembly.
caravel
« Tank Monitor | Top | - »
Fresh water tank repair and rebuild black and grey water valves Sierra Skier LP Gas, Piping, Tanks & Regulators 0 07-25-2018 11:55 AM
grey and black valves need replacing, reduce to 1 valve? dcorona Waste Systems, Tanks & Totes 15 06-30-2015 11:20 AM
Black and Grey Tank Valves Hard to Pull Ssmookler Plumbing - Systems & Fixtures 2 03-08-2015 05:22 PM
Minuet Water Valves - What is What? Grey and Black ply5013 Waste Systems, Tanks & Totes 1 11-16-2012 12:04 PM
Replacing black/grey with a larger grey whitney Waste Systems, Tanks & Totes 11 05-08-2012 07:47 PM
