Old 06-27-2018, 01:06 PM   #1
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
?? for those with dump valve leaks. 😳
....anyone have an external leak, not thru the discharge but out the tank cover drain holes?
This past Spring get-ready I noticed a small leak after filling the grey tank with 5gal.
Could there be a seal leak at the slide housing that would leak externally into the pan?
POI...the slide operates smoothly without binding.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
Old 06-27-2018, 01:17 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I have not had such a leak. The valves on my trailer are screwed to a mount that is held on to the tank outlet by a clamp. So there are 2 sources for such a leak. Thr seal between the valve mount and the tank and the seal between the valve and the valve mount. In addition one of my valve bodies had small cracks in it. I think cutting an inspection port may be in your near future.
Old 06-27-2018, 01:32 PM   #3
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
It could be one of many places a leak could occur.
- plastic flange that is between the tank and valve - had two cracked last year on our 1994 trailer
- valve body
- rubber Fernco fittings
- cracked ABS pipe
Here is a picture from an older 1989 trailer, our current 1994 trailer is ever so slightly different and your trailer is likely somewhat similar to our 1994 and should give you an idea of what to look for.
Cut an inspection hole and get a piece of flat galvanized HVAC duct work to cover the hole. Airstream dealer will have the parts.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-27-2018, 01:50 PM   #4
Thanks guy's...just the info I needed. 👍
CB..the pic gives me a much better idea of where the inspection hatch needs to be. 😂
The leak at 5gal pointed me towards the valve but I wasn't sure of how the seals were installed on the slide.
Molly Ivins
Tahawus
Old 06-29-2018, 08:18 PM   #5
Well....
....it was the grey tank drain, opened it up today.
The flange was cracked on the tank side. OK, it may have had a defect. 🙄
But then I got it off and noticed the probable cause.
I believe the compression clamp was overtightened at install, warping the inlet and cracking the flange.
What thinks 'ye?
Thank You JC😟
ID:	315504   Click image for larger version
Molly Ivins
Tahawus
Old 06-29-2018, 08:30 PM   #6
Overkill Specialist
GMFL's Avatar
2020 30 Globetrotter
2014 23' International
Dadeville , Alabama
I think you made the right choice to go to Cleveland.
Old 06-30-2018, 06:45 AM   #7
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Now that's a great photo of the valve arrangement & plumbing. I've been thinking about this job as something that we all much tackle eventually and my turn is coming any day now.
1. How much space is there between the cover and the tank.
2. . I'm thinking along the lines of how best to cut the access panel without putting a hole in the tank ???
3. Thinking ahead it looks as if we need to remove the 4 screws that sandwich the valve in place and slide the old out and new in. Is this an oversimplification and is it really that simple ???
4. What challenges are there to encounter in doing that ???
5. The nice top view is deceiving as seen. Working from below it looks to be difficult to access the screws on top of the valves. Do we need to cut the access to the front side also to gain better access ??
6. Do most replace with Thetford valves or Valterra and are they interchangeable.
Thanks all in advance.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-30-2018, 12:03 PM   #8
It is difficult doing it upside down...the hex head screws on the worm drive clamps are doable 1/4 drive socket on a 4" extension. If your replacing the white slider valve, it must be cut out and a separate collar used to install it on the discharge side
The compression clamp on the tank side was under so much tension it almost took off my pinky when the Dremmel bit cut thru it...why the outlet was so deformed.
ODM is sending the parts...good thing is the slider is fine all I need to replace is the tank side flange, seal ring and new clamp.
Rust tells me it been leaking for a while. 😳
More photo's...
I should have widened the outer edge 1.5" would have been better. 👍
ID:	315548   Click image for larger version
ID:	315550   Click image for larger version
ID:	315552   Click image for larger version
ID:	315554   Click image for larger version
Molly Ivins
Tahawus
Old 06-30-2018, 05:52 PM   #9
1988 32' Excella
Robbinsville , New Jersey
First flush the tanks, then flush the tanks.
I used a 4 1/2" grinder with cutoff wheel to cut the pan.
Major thing to watch for is wires for sensors, on my 88 the wires were 8-10' longer then needed (after installed) and just laying loose in the pan.
Cut small hole, then bigger. Make the hole as big as possible while trying to leave enough past the edges of tanks to drill through (without hitting the tank) and rivet new piece on. You will wish for more room to work.
I went with Valterra valves on mine.
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
Mildew?😳 akfishmama General Repair Forum 2 02-08-2016 11:21 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
