Old 08-13-2023, 03:18 PM   #1
2023 30' Globetrotter
Los Angeles , California
Unhappy Did someone steal my black tank valve pull assembly?
Hello everyone. Day five of the full-timer adventure. This morning I noticed that Id left unlocked or open 🤦🏻*♂️🤦🏻*♂️🤦🏻*♂️🤦🏻*♂️ my tail storage compartment. I saw that my sewer hose was gone as well as the tool that I use to unscrew the drain cover. That was annoying and puzzling. As the guy at NAPA said, Whos gonna put that on eBay? Ok. Solvable problems. I have a spare hose.
Then the plot thickened. When I got back with a tool to open the drain for emptying my very full gray water tank, I noticed that there was only one valve pull. My black water tank valve pull either fell off 🤦🏻*♂️ or was removed 🤬.
My question is which parts am I missing? In other words, what do I need to order? If anyone can help, Id be grateful.
ID:	435406   Click image for larger version
Mister Eff is offline   Reply With Quote
Old 08-13-2023, 03:39 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
This link will take you to the Airstream Parts manual, check page 230:
https://www.airstream.com/wp-content...Parts-Book.pdf
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 08-13-2023, 03:44 PM   #3
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
On my trailer I had to replace the black tank valve. Doing that nasty job I learned that the pull rod is threaded. Same as the exterior handle on the other end. It's quite possible your pull rod simply twisted off then jiggled out while on the road.
kscherzi is offline   Reply With Quote
Old 08-13-2023, 04:14 PM   #4
LAWBC's Avatar
2012 23' Flying Cloud
GVA , British Columbia
missing handle
I see the valve is there look ahead of your thumb that's the valve threaded portion going into the black tank, what your missing is the pull handle and threaded male stem union that has come off, and I suspect that the threaded portion was attached without Thread-Lock and may have vibrated off, or as you suggest,,,.it walked.
The dwg is not an as built compared to what your pic shows it has 2 parts not a single valve rod eg. https://valterraparts.com/valterra-r...-12vp-6-and-9/
Laurence
LAWBC is offline   Reply With Quote
Old 08-13-2023, 11:25 PM   #5
Thanks!
Much appreciated. This is exactly the sort of thing I was looking for.
Old 08-13-2023, 11:26 PM   #6
Fantastic. Again, much appreciated.
Old 08-13-2023, 11:29 PM   #7
Thank you
I appreciate your thought and time put into your response. As I (of course) had a completely full black tank, I had to problem solve for a dump today. I learned about the two-piece rod while removing then moving the gray water valve handle over to the black water side.
Old 08-13-2023, 11:32 PM   #8
Thank you all so much
Really wonderful. I had to dump my completely full black water tank, so I went about removing the gray water tank release handle and screwing it onto the black water side. It worked, thank god, and thanks to you all I know the part I need to order to make things whole again.
Old 08-14-2023, 10:37 AM   #9
MMCMRET's Avatar
2021 25' Flying Cloud
Fredericktown , Ohio
Hmmm. I have little metal locking wires that go over each side of both handles.
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
MMCMRET is offline   Reply With Quote
Replacing grey and black valve assembly rechewjr Our Community 0 05-15-2022 11:15 AM
Black tank pull handle screw head broke off underneath and cant empty tank. HabitatGuy Classic Motorhomes 18 06-21-2020 08:35 PM
Black Water "pull valve" problem tracenuttall Waste Systems, Tanks & Totes 2 08-22-2015 09:15 AM
Need help on Black water valve assembly- 1966 CtRobert 1965 - 1969 Globetrotter 0 11-03-2010 04:47 PM
Black water dump valve push pull rod missing firetech51 Waste Systems, Tanks & Totes 2 08-26-2009 09:44 PM
