An LED style is what I was thinking to that uses the original wiring set up, I was thinking with the FW pump switch built in also. But I do like the idea have having a thermometer for the fridge also. I been using a "meat" thermometer that goes down to 32 degrees in the fridge. Want to go a wireless thermometer so I don't have a thin braided wire coming out through the door seal. Another thought on the thermometer wiring was to run it through where the thermister wires run through the back of the fridge, would like to run small
12v wires through the same area to be able to plug in a small
12v hard wired fan in the fridge. That way I don't have to buy batteries for the battery powered ones.
