08-21-2018, 03:36 PM
2017 25' Flying Cloud
Florence
, Alabama
Contaminated fresh water from grey tank overfill
While I was out, DW had over filled the grey tank to a point that water was coming from the fresh water fill panel, I assume the vent port in there. Do I need to completely drain, fill and sanitize the fresh water system now?
The Colonel and Southern Belle
08-21-2018, 04:00 PM
1994 34' Excella
Warren
, Manitoba
Are you connected to city water? If so, your check valve in the potable water supply pump is probably not closed. If you are not connected to city water there is no way that grey water can enter the potable water tank! Drain the grey tank, and run the pump with the city water shot off. Run for several minutes to lower tank level, shut off and turn on city water and see if your potable water tank refills. You MAY have cleaned out the check valve by pumping, but, you might have to dissassemble and clean manually. Good luck, Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
1974 Argosy 26
Morrill
, Nebraska
And it did not run out of the shower basin? Something doesn't sound right here.
There is no connection between the grey water tank and the fresh water tank.
Grey water would back into the shower pan/tub not into the fresh water tank.
08-21-2018, 04:01 PM
2017 30' International
Broomfield
Weird - I thought the vent port for the black and grey was on the roof, and the vent for your fresh water tank was at the fill port.
Anyhoo is definitely sanitize the fresh water tank with bleach. Good idea to do that once or twice a year anyways.
08-21-2018, 04:20 PM
Florence
, Alabama
Ok, I came back from a meeting and started tearing down to leave. When I went to hook up the sewer hose is when I fount the water running out of the fw service panel. I had dw check grey tank and it was 100. Didn’t check shower floor, should have I guess, but I hurriedly opened grey tank drain to lower tank volume. After a while water stopped coming from panel. Somewhere in the process I shut off city water and disconnected hoses so it may have been coincidental but not same issue. I’m at another site tonight and then home tomorrow. I’ll try cbwell’s comment and see what happens
08-21-2018, 04:38 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
It was not grey water coming from your vent at the fresh water tank fill port. Assuming you were attached to city water, the check valve in your water pump was stuck, and allowing your fresh water tank to fill via the city water pressure coming through the pump. Then when it filled, it came out of the vent hole next to the fill port.
It is a coincidence that it stopped when you drained off some grey water. Or it stopped because at some point in the process your disconnected city water, as you mentioned. There is absolutely no connection between your fresh water thank and your grey tank, so there is no need to disinfect.
08-21-2018, 04:43 PM
Florence
, Alabama
Good to know, makes perfect sense
08-21-2018, 04:46 PM
Florence
, Alabama
However, FYI, I’m having a beer and checking this now. Drained down fw with city off. Have turned city back on and will check fw level in a few (after this beer).
08-21-2018, 04:53 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
It might take a while or it might be intermittent as most are that do that. Enjoy the brew and don’t worry!
08-21-2018, 05:05 PM
Florence
, Alabama
Seems to be holding for now. Somewhat puzzling since I filter city water in. Hopefully just a fluke. Thanks for all the input.
08-21-2018, 05:11 PM
Tampa
I think you hit on a coincidence.
1. Your fresh water tank was overflowing.
2. Your grey water level said 100.
Then you assumed that the grey read 100 and CAUSED the fresh to overflow.
08-21-2018, 05:13 PM
Florence
, Alabama
Yep, tough thing is telling the dw she didn’t cause it, lol
08-21-2018, 06:44 PM
1994 34' Excella
Warren
, Manitoba
Time to be humble!!!! Give the DW a hug!! Glad things worked out. Even with the filter on city water, there could be some crud in the tank that got into the check valve in the pump. Usually running and shutting off a couple of times clears things out of the check valve. Chris
ACI #7394
1994 Excella 34'
Hensley Hitch
08-21-2018, 07:45 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
I think every one is on to the fact it’s prob going to be the check valve in the pump.
The FRESHWATER system and the GRAYWATER system are not connected. To each other. They are in fact to completely different systems.
08-22-2018, 10:45 AM
2013 31' Classic
billings
, Montana
No way
08-29-2018, 10:23 AM
2010 27' FB Classic
Austin
In my experience, if you had gray water backed up into your shower stall
you would know it, even if you had drained the system before you looked. The shower will stink and there will be grit all over the floor. I get in a lot of trouble with the chief cook and bottle washer when I let that happen.
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
08-29-2018, 04:16 PM
2018 30' Classic
Jacksonville
A. No, its not grey water in the potable tank.
B. But IF it was grey water the water coming out of the vent it would stink. The water now coming out of the tap when pumping from the tank would stink. The tap water would also taste terrible...….no it would taste TERRIBLE. Next time a little water sniff test is in order.
C. I treat my aeration system at the house and the trailer on the first of every month with a mild bleach solution. I let the trailer sit a day, then flush it out. It keeps the choloriforms (sp) in check.
09-02-2018, 10:53 PM
2019 25' International
Issaquah
What about this
At the International Rally in Salem this year there was an issue with the city water (algae contamination). I chose not to hook up to city water as I could make it on my home filled fresh water tank. As I walked the grounds, I saw many rigs hooked up to the city water. My question is did they contaminate their lines, and to what extent? When hooked up to city water, no city water enters the fresh water tank right? But the line from the entry point is shared at some point? So would they have to decontaminate when they went home?
09-03-2018, 12:51 AM
Sag Harbor
, New York
Yes they should IMO, and the sooner they can get a bleach solution in the lines, the better off they will be. This may require putting bleach in the water tank, then pumping it through all the lines.
ASAP IMO.
Peter
PS -- "water tank bleach sanitize" search results: https://www.google.com/search?q=wate...com&gws_rd=ssl
