Old 11-22-2023, 06:04 PM   #1
Jarrid's Avatar
1968 26' Overlander
Flower Mound , Texas
Composting toilet
Hello to all. I have a ‘68 Overlander. Typical of that model is floor rot in the aft area as well as the entry door.
I’ve just learned my black tank is leaking. It will need to be replaced. I figure if that is in need to be replaced, I might as well have all the copper plumbing replaced with PEX.
Here comes the question. Should I replace my existing toilet with a composting toilet? Would this would negate the need for a black tank? Can urine go into a grey tank?
Thank you in advance.
Jarrid
Jarrid is offline   Reply With Quote
Old 11-22-2023, 07:06 PM   #2
1966 22' Safari
Fredericksburg , Texas
Our 55 never had a black tank. They just used a gopher hole. So, we went with a Nature’s Head composting toilet instead of going back with a black tank and a typical toilet. It has a reservoir for urine that is emptied after a trip. We did install a couple of 16 gallon grey tanks piped together for the sinks and shower.
Bubba L is offline   Reply With Quote
Old 11-23-2023, 09:04 AM   #3
Jarrid's Avatar
1968 26' Overlander
That sounds like the best option.
My ‘68 did not have a gray tank. Just a black tank. It’s just forward of the rear bumper. I’m wondering if placing the two connected gray tanks near but aft of the axles would be ideal.
Old 11-23-2023, 10:28 AM   #4
1966 22' Safari
I always empty the grey tanks before leaving a campsite. So, if the tanks are empty in travel, I wouldn’t think placing them aft of the axle would matter.
Old 11-23-2023, 10:51 AM   #5
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Hello, I've done similar things on a few 60/70'sAirstream's but I'll focus on our '68 Overlander. One of my main goals is to get as large a gray tank as I can so out comes the black tank (ours was fine) and then I source the largest tank that will fit the opening. I believe inn the '68 it is 35 gallons. This is kind of funny because the only thing that goes in it is the kitchen sink. We have basically eliminated the bathroom and in effect created a rear bedroom. The toilet we went with is a porta-potti "Curve", sleek and somewhat stylish, electric flush, fairly compact and tall enough to be comfortable. It stows in a closet for travel and when not in use. We also don't have a shower in the trailer, there is an outdoor one. So, kitchen sink, porta-potti, outdoor shower, works for us. If we need to poop in the trailer (under 5 times is 3.5 years) we use the bag method popular with van folks and treat it like dog waste. Bottom line is at some point someone has to deal with waste in some way, and we all know who that usually is. We have done multiple moths ar RV parks with this set-up. And yes, replace all that copper with pex.
Good luck, Mark D
mrdes8 is offline   Reply With Quote
Installing a composting toilet gamana Sinks, Showers & Toilets 18 04-03-2017 09:48 PM
Composting toilet: winter use? Joyfulgirl Sinks, Showers & Toilets 5 08-27-2011 09:45 PM
Your questions about our Composting Toilet FLYNCLD Waste Systems, Tanks & Totes 55 03-28-2011 06:04 PM
Anyone installed a composting toilet? casaalumina Sinks, Showers & Toilets 15 10-08-2008 01:53 PM
Composting toilet replacement Phaedrus Sinks, Showers & Toilets 4 10-17-2003 07:19 PM
