Old 11-22-2019, 03:47 PM   #1
CruizinDux's Avatar
Tracktown USA , Oregon
BW flush hose connection
Has any one replaced the exterior BW flush hose connection?
I replaced our VacBR/Ck Val last fall before our trip to ME. I only used it a few times EB but more WB after a few cold nights. It appears the hose connection has a slight leak.
http://www.airforums.com/forums/f542...27845-132.html Here is the link for the replacement of the plastic OEM BW Vac BR/Ck Val with solid brass one....now with a grill cover for the access hole. Sure did help getting the warm air back there.
I found the AS number in my parts pdf but it appears to be proprietary since it did not indicate a shurflo etc part. I also confirmed the shurflo does not make that part. Nada at Valterra, etailer. Seems everyone caries the FW connection
Might grab this and simply drill out the CkVal, since I already have one with the new VacBr/Ck Valve downstream and do not want a hindrance during winterization.
https://www.valterra.com/product/wat...-black-bulk-2/
Has anyone replaced the OEM part with an aftermarket. I'm thinking the AS part is my only option.
CruizinDux is offline   Reply With Quote
BW flush hose connection CruizinDux Waste Systems, Tanks & Totes 0 11-22-2019 03:47 PM
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 37 02-06-2018 01:53 PM
Hooked hose to flush valve instead of city water... Denis4x4 Waste Systems, Tanks & Totes 9 09-25-2007 09:50 AM
No Fuss Flush and Fresh Water Hose? docbluedevil Waste Systems, Tanks & Totes 3 04-07-2004 10:07 AM
Flush out connection JLD Waste Systems, Tanks & Totes 2 01-04-2003 09:06 PM
