Old 11-22-2019, 03:47 PM   #1
CruizinDux's Avatar
Tracktown USA , Oregon
BW flush hose connection
Has any one replaced the exterior BW flush hose connection?
I replaced our VacBR/Ck Val last fall before our trip to ME. I only used it a few times EB but more WB after a few cold nights. It appears the hose connection has a slight leak.
http://www.airforums.com/forums/f542...27845-132.html Here is the link for the replacement of the plastic OEM BW Vac BR/Ck Val with solid brass one....now with a grill cover for the access hole. Sure did help getting the warm air back there.
I found the AS number in my parts pdf but it appears to be proprietary since it did not indicate a shurflo etc part. I also confirmed the shurflo does not make that part. Nada at Valterra, etailer. Seems everyone caries the FW connection
Might grab this and simply drill out the CkVal, since I already have one with the new VacBr/Ck Valve downstream and do not want a hindrance during winterization.
Has anyone replaced the OEM part with an aftermarket. I'm thinking the AS part is my only option.
CruizinDux is offline   Reply With Quote
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 37 02-06-2018 01:53 PM
Using Water Hose to Flush Sewer? Fly at Night Plumbing - Systems & Fixtures 69 09-20-2013 08:38 AM
Hooked hose to flush valve instead of city water... Denis4x4 Waste Systems, Tanks & Totes 9 09-25-2007 09:50 AM
No Fuss Flush and Fresh Water Hose? docbluedevil Waste Systems, Tanks & Totes 3 04-07-2004 10:07 AM
Flush out connection JLD Waste Systems, Tanks & Totes 2 01-04-2003 09:06 PM
