Old 08-03-2019, 10:19 AM   #1
2019 27' Tommy Bahama
Ocean Pines , Maryland
Blue Boy
My wife and I are interested in purchasing a Barker 42 gallon 4-WheelerTote Along. Although it is highly rated, the only issue I see is that the connection from the AS holding tanks are about the same level as the waste water input. Is that a show stopper for us?
Docbutch is offline   Reply With Quote
Old 08-03-2019, 10:23 AM   #2
Sag Harbor , New York
Could you please provide a link to the product?
Old 08-03-2019, 10:25 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The sewer hose will probably fill with black water but will siphon into the blue boy. When you are ready to dump just lift the hose to drain the residual. Use a short sewer hose. Another issue is the weight, about 300 pounds full.
Old 08-04-2019, 07:16 AM   #4
https://www.amazon.com/Barker-27844-...gateway&sr=8-1
Old 08-04-2019, 07:20 AM   #5
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
It makes it less than fun, but you can work around it.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 08-12-2020, 02:56 PM   #6
2020 27' International
Neptune Beach , Florida
Blue boy
I was just curious if you ended up buying the 42 gallon blue boy? We are thinking of the same and wondered if you were happy with it?
NascarNomads is offline   Reply With Quote
Old 08-12-2020, 03:18 PM   #7
dznf0g's Avatar
Oswego , Illinois
I have a very old two wheeler 22 gallon blue boy. The 4 wheeler models make 40 gallons doable. But both have height issues with AS low drain points. Some sites are fine, some are very difficult.
-Rich-
Old 08-12-2020, 04:03 PM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
Keep in mind that a full 42 gallon blue boy will weigh about 300 pounds.
Old 08-12-2020, 04:26 PM   #9
dznf0g's Avatar
Oswego , Illinois
Right, but the 4 wheelers alleviate that issue quite a bit. I certainly wouldn't want more than my 22 gallon 2 wheeler.
-Rich-
Old 08-12-2020, 04:56 PM   #10
"Cloudsplitter"
42gal, 4 wheels, 300lb...does it have hitch and Michelin LT's to toe it to the dump?😂
Old 08-12-2020, 05:03 PM   #11
dznf0g's Avatar
Oswego , Illinois
Ppp hitch and teeny little LT michelins , but they quit making the size I need, so I'm going with RIBs
-Rich-
Old 08-12-2020, 06:27 PM   #12
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
Blue Boy
I need one of these, how do you get around the height issue. Thanks. Have you had issues with pneumatic tires?
Silvr_Bullet is offline   Reply With Quote
Old 08-12-2020, 08:34 PM   #13
dznf0g's Avatar
Oswego , Illinois
My, very old, 22 gal 2 wheeler has solid tires. So, using an extra long hose can usually get me to an elevation that works. Sometimes ya just gotta fill the hose and work it like a slinky to work a half gallon to a gallon at a time. This is gray water exclusively, we can go the better part of 2 week on black and i cannot ever remember hauling black water since getting the AS with a 39 gallon tank.
A 90* elbow, helps a lot, if your fill port on the blue boy is on top.
-Rich-
Old 08-12-2020, 09:47 PM   #14
Rich W's Avatar
I'm In , Kentucky
A long slinky with the blue boy downhill from the AS helps. You can also raise your stabilizers and lower the AS on the jack to give more elevation to the drains. You won't be able to empty the tanks but you will get quite a bit out. It pretty much fills our 15-gallon Tote-N-Stor 25607.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 08-12-2020, 09:52 PM   #15
2007 27' Safari FB SE
NW Oregon in a nice spot , Oregon
You are a far braver sole than I. Care to help the curious of us know why you want such a big one?
Good luck dealing with this one!!
bweybright is offline   Reply With Quote
Boy Oh Boy! my new '56 Flying Cloud! urbanfood 1956 - 1959 Flying Cloud 171 06-07-2018 07:14 AM
What is the best size Blue Boy tank? silverback Waste Systems, Tanks & Totes 55 05-28-2011 11:04 AM
Best size blue boy tote? Lumatic Waste Systems, Tanks & Totes 23 06-14-2010 05:29 PM
thetford or blue boy or something better? Karterlin On The Road... 4 09-08-2009 10:03 PM
Oh boy, Oh boy till Our Community 19 05-05-2005 07:26 PM
