Old 04-15-2017, 12:01 PM   #1
Waco , Texas
Question Black water tank replace
My wife and I purchased a 1975 sovereign and we are redoing everything on the inside, however there is no black water tank or clear water tank does anyone know what kind of tanks it takes and where the best place to buy them from ?
MaximusAir is offline   Reply With Quote
Old 04-15-2017, 07:00 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
You can get a correct replacement fresh water tank form Vintage Trailer Supply. Not cheap, but it fits in the bay just ahead of the axles where it's supposed to. Black and gray tanks ... That depends a lot on your plumbing arrangement. VTS will custom spin weld fittings into tanks that will fit inside your frame. These tanks need to be fully supported from below, not just strapped in. I've also heard people mention Inca Plastics, which makes an entirely different type of tank. First thing is to decide where you want everything to go, then figure out where you can put the tanks to make it work.
TheGreatleys is offline   Reply With Quote
Old 04-15-2017, 08:23 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Another source is Inland RV in CA..
By the way I do not think VTS makes the tanks. This does not mean they are not a good source. I recently got a tank through VTS made by Inca Plastics.
Use Black Water Tank as Aux Fresh Water Tank? DaytonaDan Plumbing - Systems & Fixtures 20 10-26-2016 07:53 AM
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
black tank and toilet flange; when is it necessary to replace the tank? Globie64 Waste Systems, Tanks & Totes 7 09-07-2011 04:04 PM
Need to replace black water tank fisherjdou Waste Systems, Tanks & Totes 7 06-22-2010 08:40 PM
