Old 06-19-2021, 04:55 PM   #1
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Black tank sprinkler
Does anyone know if the black tank sprinkler is an actual sprinkler that sprays the entire inside of the tank. Or is it just a filling valve connected to an internal hose or… which allows you to fill the black tank with fresh water used to flush it clean.
- Stewart
s1000pre is offline   Reply With Quote
Old 06-19-2021, 05:12 PM   #2
2021 27' Globetrotter
Sumterville , Florida
If it is the same “No fuss flush” as my previous coach it is a sprayer about the size of my little finger that sticks into the tank. In the previous case from the top and to one end opposite the drain. Water sprays from an array of small holes.
SVTOTEM is offline   Reply With Quote
Old 06-19-2021, 05:13 PM   #3
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
I believe it to be multiple jets of water (or a sprinkler as you put it - although a stationary one) designed to spray around all sides of the tank. This is because on several occasions I have re-dumped my black tank using it and seen bits of toilet paper pulp come out that were not there in the original dump. And it was too much to be just what was added since the prior black dump.
And I have a macerator toilet and macerator pump, so the poo is generally dumped very thoroughly.
rowiebowie is online now   Reply With Quote
Old 06-19-2021, 05:45 PM   #4
s1000pre's Avatar
I have the macerate as well and love it! No smell!!!
- Stewart
Blank tank above floor or below in renovation? kevinkatz Waste Systems, Tanks & Totes 1 04-19-2019 07:16 PM
Neighbor's Sprinkler Left Mineral Deposits drftboat General Repair Forum 2 10-18-2016 08:00 PM
wanted key blank for 69 Overlander bgow 1965 - 1969 Overlander 4 10-04-2015 11:15 PM
Dimensions for Blank Tank Holder Box sought TheProfessor Waste Systems, Tanks & Totes 4 08-04-2010 07:53 AM
Air Conditioner/Sprinkler Unit ?? Condoluminum Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-10-2004 05:53 AM
